u-joint replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Feb 13, 2010.
  1. Feb 13, 2010 at 5:44 PM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    gonna go ahead with the replacement, got the part today, and have an extra pair of hands coming by on monday or tuesday to help( doesn't hurt there is a case of old styles in the fridge plus some dewar's white label):D.
    Any good write-ups on it?
    lemme know,
    later days, willie mays:D
  2. Feb 13, 2010 at 7:08 PM
    ywen
    ywen Well-Known Member
    can I come to watch/help?
  3. Feb 13, 2010 at 7:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Just make sure you make note of the original location where it bolts up to the yoke flanges, mark it (front & rear) so you'll bolt it back up exactly the way it was........:cool:
  4. Feb 13, 2010 at 9:25 PM
    4421.frank
    Southside chicago
    just mark it with the soap stone? Also, do put in park with the emergency brake on and jack it up on the front, or do I leave in neutral and jack it up from the back, with some wheel chocks in the front?
  5. Feb 13, 2010 at 9:26 PM
    4421.frank
    Southside chicago
    if you're in the immediate chicago area next week, sure, but bring another six pack:cool: aDIOS, muchachos
  6. Feb 13, 2010 at 9:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah, put some jack stands under rear axle, chock the front wheels, put it in neutral......:cool:
  7. Feb 14, 2010 at 1:05 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    look on you tube there is some great how to videos once you weed out the b/s
  8. Feb 15, 2010 at 4:20 PM
    4421.frank
    Southside chicago
    just finished the repair, not too bad. Jacked the rear up after lossening the bolts from the yoke. Then took the u-joint off, after marking it.
    Then came the bullshit :mad:
    I pulled out the locking rings and then......pounded and pulled and could not get the spider free. Finally after an hour I went to a local shop and asked them to get this spider out for me, they did it in a 15 minutes and charged me $20 :eek:, but what else could I do?
    After that everything went smoothly, after installing the new u-joint I greased all other grease fittings and snugged up the bolts.
    Took her for a short spin, didn't notice the noise as before and didn't notice anything new.
    If this installed wrong it would have made some type of noise, correct?
    Also, while looking under the truck I noticed another set of u-joints located just after the carrier bearing, could the noise be coming from there as well?
    finally, thanks to evryone who gave me some tips, your guidance is appreciated.:)
  9. Feb 16, 2010 at 11:27 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The 2 U joiunts knuckled so close together are non serviceable & if bad the whole unit has to be replaced( As far as I know theres no way to punch it out).....:cool:
