U Joint Service Interval
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 19, 2022.
  1. Jan 19, 2022 at 2:08 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    I keep coming across you must grease u joints every 5,000 miles. Is this what everyone else has heard?
    Has anyone found grease-able u joints that can go longer than 5K before being greased?
  2. Jan 19, 2022 at 2:16 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I grease mine every time I do an oil change, that's around 10k miles not had any issues.
    For what it's worth if your truck it 2WD it may not even have greaseable U joints.
    New trucks even the off-roads are coming with sealed joints not greaseable.
    I use Spicer joints, they are the OEM. (They make the ones for Toyota.)
    PzTank likes this.
  3. Jan 19, 2022 at 2:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m still on OEM joints.
    I grease mine once a year in October.
    I drive about 9-10k per year. I’m at 149k now.
    I use Lucas Red n’ Tacky #2
    knayrb and PzTank like this.
  4. Jan 19, 2022 at 2:36 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Every oil change no questions about it
    blu92in99, 2015WhiteOR and SR-71A like this.
  5. Jan 19, 2022 at 2:38 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Same.
    They will last a long time without grease no doubt. But why bother. Its so easy to grease them while you're already under the truck.
    Sig45 likes this.
  6. Jan 19, 2022 at 2:59 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Once every year... sometimes a year and a half. Still on OEM at 120,000 miles.
  7. Jan 19, 2022 at 3:05 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Probably do mine twice a year. I use the Lucas Red and Tacky grease. Mine have zero play at 170K miles.
    TnShooter likes this.
  8. Jan 19, 2022 at 4:45 PM
    TacoBell07
    Four door 2wd Taco
    I use Mobil 1 10,000 mile oil so i would probably doing greasing of joints then.
    Had Moog sealed u joints since 240K now I'm at 288K and seems like one at least is starting to fail clicking.
    I will never buy Moog again, hoping my Moog ball joints don't wind up going out too.
    So I think I will go with Spicer this time only question is greaseable or non greaseable.
  9. Jan 19, 2022 at 4:49 PM
    EarlHickey
    EarlHickey Active Member
    2006 TRD Off-Road
    My owners manual says every 15K. I only drive this truck around 5K a year. Not a big DIY guy anymore but it doesn’t matter how many times I ask the lube jockey to grease them, they won’t do more than one or two. So I crawl under there once a year and do it. I figure before it starts snowing and 4WD comes into play is a good time.
    SR-71A likes this.
  10. Jan 19, 2022 at 4:55 PM
    TnShooter
    Deogee
    STOCK
    The front driveshaft is the one that gets neglected the most at lube shops.
    The one closest to the cat is a PITA when the cat is hot. You have to go over it to get to the zerk.
  11. Jan 19, 2022 at 4:58 PM
    TacoBell07
    Four door 2wd Taco
    Does your driveshaft have 3 u joints on it and is it a two piece ?
  12. Jan 19, 2022 at 5:14 PM
    TnShooter
    Deogee
    STOCK
    Yes it should have 3 joints on a long/short bed double cab 2WD.
  13. Jan 19, 2022 at 5:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    My truck has 5 U-joints with the zerk in the cap. EZ PZ to pump a stroke or two into each joint at each oil change interval. I run a 5 kmile oil change interval.
    It doesn't take much to lube a joint.
  14. Jan 19, 2022 at 6:58 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I grease all 5 on the rear shaft every 5-10k. I replaced all 5 after 100k as a preventative measure. I’m hopeful the carrier bearing will go 200k+.
  15. Jan 19, 2022 at 7:14 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    Every 5000 or Six months. Get a good grease gun and it's easy.
  16. Jan 19, 2022 at 10:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What?
    You have 5 universal joints on the rear drive shaft?
    I hope you meant 3 on the rear driveshaft and 2 on the front driveshaft. Total of 5.
  17. Jan 20, 2022 at 10:17 AM
    TacoBell07
    Four door 2wd Taco
    I replaced my carrier bearing with a Spicer one which is a TRUE OEM replacement. the same Spicer part was taken off and it was not making any noise or any signs of wear at 182,000 miles.
  18. Jan 20, 2022 at 10:18 AM
    TacoBell07
    Four door 2wd Taco
    Yes exactly mine has one at the yoke near tranny, one after carrier bearing and right before the rear diff. there is one too.
    TnShooter[QUOTED] likes this.
  19. Jan 20, 2022 at 10:19 AM
    TacoBell07
    Four door 2wd Taco
    If it is over-greased will grease fly out like when greasing ball joints?
  20. Jan 20, 2022 at 10:19 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    X3 - every oil change.
    SR-71A[QUOTED] likes this.
