U Joint Service Interval
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jan 19, 2022.
  1. Jan 20, 2022 at 10:20 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    No, it just oozes out.
  2. Jan 20, 2022 at 10:51 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    My Prerunner doesn’t have grease fittings. 111K with no issues.
    TacoBell07[OP] likes this.
  3. Jan 20, 2022 at 10:51 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Has anyone used the sealed u joints as well?
    Do they throw grease over time too?
    Generally if I find grease I think there's something wrong there.
  4. Jan 20, 2022 at 10:52 AM
    TacoBell07
    Four door 2wd Taco
    The original u joints still on the truck then?
  5. Jan 20, 2022 at 10:53 AM
    ARB1977
    North Texas
    Yes
  6. Jan 20, 2022 at 11:04 AM
    WhiteYota06
    WhiteYota06 Active Member
    I've re-done my u-joints twice (250k total on the truck). As a 2wd, I had 'life time greased' joints from factory. Replaced with with greaseable, and greased them every oil change. It was fine but got kinda tired of it shooting up all the excess grease under the truck and cleaning that off. Not that it was a big deal. So when I re-did them for the 2nd time, I went back to the life time greased units. Theres many u-joint videos out there and some claim these are built to better tolerances as well. I've no actual proof of that, I just didn't want to keep cleaning grease off the underside of the truck.
  7. Jan 20, 2022 at 11:04 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I know I should have I but never greased my OEM u-joints. I replaced them at about 120K when my center bearing needed replacing. I went with Spicer non-greasable u-joints. The OEMs looked good and they had no play but it was a no brainer to me to replace the OEM u-joints since I had the driveshaft out and it could be another 100K miles before replacing the center carrier again.
  8. Jan 20, 2022 at 12:23 PM
    TacoBell07
    Four door 2wd Taco
    This is same with me. I've already got greaseable ball joints and wished I'd gone with something else, something not Moog. I really don't want more grease frankly like you say its a pain to deal with. I wonder if Spicer sealed u joints last anywhere long as the Spicer grease able ones do.
    I suspect this could be the case especially if they were designed to truly keep and retain grease for 100K miles.
    Greasable joints on other hand seems like they are not sealed as well and made to leak grease.
    Getting a greasable u joint and just greasing then not greasing them again is not the same as getting seal u joint since these are made not to leak at all?
  9. Jan 20, 2022 at 12:32 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Correct, 2 & 3. Brain damage has set in.
    Jimmyh[QUOTED] likes this.
  10. Jan 20, 2022 at 2:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The only reason I corrected you was so someone doesn't waste a day looking for the missing two universal joints on the rear shaft. :eek:
  11. Jan 20, 2022 at 4:25 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The side benefit of regularly greasing your u-joints is they spin/splatter grease all around the underside, which helps protect from corrosion.
  12. Jan 21, 2022 at 4:50 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Exactly :D
    dk_crew likes this.
  13. Jan 21, 2022 at 1:15 PM
    HansLanda
    HansLanda Well-Known Member
    Mine unserviceable ones lasted 125k miles. Replaced with Spicer.
    I grease mine every other oil change. 10k mile interval.
  14. Jan 21, 2022 at 8:03 PM
    TacoBell07
    Four door 2wd Taco
    Decided to go with Spicer sealed joints.
