U joint wont take grease
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, May 31, 2018.
  1. May 31, 2018 at 5:59 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I replaced all 3 u joints in the driveshaft last week with Spicers and it's been riding smooth.
    However, when i greased them before putting the shaft back on, one channel on the middle joint wouldn't take grease. The two caps which are inline with the zerk did just fine but the other two, no matter how much grease i pumped in there, they wouldn't spit any. I figured I'd drive on it for a few days and try again, thinking maybe things would settle. Tried to grease it again today and still no joy. Am i going to have to take this thing off again and reinstall it? :frusty:
  2. May 31, 2018 at 6:08 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    take a small punch or a nail or something similar and push the ball on the end of the zerk in. it should free it up to accept grease.
  3. May 31, 2018 at 6:57 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    When you put the u joints in did they rotate smoothly after install or were they kind of stiff?
  4. May 31, 2018 at 7:58 PM
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    The valve ball is frozen. Free it up and then grease. Did you pack them on install? Don't drive on dry bearings
  5. May 31, 2018 at 8:02 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    The zerk is taking grease ok because it's filling both cups that are in line with it, its the two that are perpendicular that won't grease.
    They were all pretty free moving when i installed them, i tapped the knuckle lightly with a hammer to make sure they sat ok and that helped loosen up the movement
    desertrunner24 likes this.
  6. May 31, 2018 at 9:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Go to a shop with a pneumatic grease gun and explain it, they should give it a few shots under pressure and that should clear things up.
    Canufixit likes this.
  7. Jun 1, 2018 at 5:38 AM
    badger
    badger Well-Known Member
    07 SR5
    You really should buy a pneumatic grease gun. They are not expensive and they make this job much easier. The pressure pulses also help free any hardened grease. It could be that your U-joint is bad though. Maybe there is an obstruction in the grease galley?
    Years ago I bought a brand new Spicer U-joint. Before installing it I just turned all the caps. One of them felt funny, so I pulled it off. The cap was only machined on one side! The other half of the cap looked like it was cast. Lesson: Just because something is brand new, doesn't mean it is good. I have found 6 or more items over the years that were fails right out of the box. One item that is particularly bad is thermostats. I always measure the opening point before installing. The last one I bought for my 460 Ford, I had to return twice. The first two did not open at the specified temp.
    PzTank likes this.
  8. Jun 1, 2018 at 5:42 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    could have a joint that is clogged
  9. Jun 1, 2018 at 10:45 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  10. Jun 1, 2018 at 11:02 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I wonder if there is a way to plug off the two caps that are inline, or otherwise keep the grease from spewing out of them... this will help force the grease pressure into the perpendicular caps.
  11. Jun 1, 2018 at 11:06 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Lightly tap the caps with a hammer. May be caps not centered. Grease taking easiest path pisdible.
  12. Jun 1, 2018 at 11:17 AM
    Pigpen
    Dan
    Northwest Montana
    This
  13. Jun 1, 2018 at 11:43 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Tap the knuckle on the driveshaft or the cup itself?
  14. Jun 1, 2018 at 11:44 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Counterpoint: use non-greaseable u-joints next time. I've always replaced u-joints with the non-greaseable type. They say they are stronger because they don't have the internal grease channels, but I use them because I have lazy-greasegunitis.
  15. Jun 1, 2018 at 11:51 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If all else fails then pull the ujoint off and swap the cap with the zerk fitting inline with the side you suspect is not getting any grease.
  16. Jun 1, 2018 at 11:55 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    People are too gentle on u joints. Get a big hammer and after a joint install bang the shaft to seat the corresponding cup outwards. Do this for all 4 cups. This allows the cross and the cups to have some clearance and flow grease. If I have time tonight I will post a video to show what I mean. I do this no matter the size from small 1” shafts up to 8” dia shafts. Otherwise if the cups are tight to the cross it won’t always flow grease. Sometimes all 4 are tight and sometimes only one.
    Jckdnls likes this.
  17. Jun 1, 2018 at 4:23 PM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    The knuckle.
  18. Jun 1, 2018 at 4:24 PM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    That is the only way I install ujoints.
