U joint Zerks MIA?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tommiet, Aug 21, 2014.
  1. Aug 21, 2014 at 5:32 PM
    Tommiet
    Tommiet [OP] Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    While up to change my oil last weekend, I grabbed my grease gun and THOUGHT I was going to hit my U joints... but no zerks on any of the u joints. Is this normal for my 2WD 2013 Taco or an I just getting too old to see them?
  2. Aug 21, 2014 at 6:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    they are there.... they are all going to be in a line on one of the 4 u joint caps.
  3. Aug 21, 2014 at 6:22 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :mad: Pre-runners don't have the zerks. Only the 4x4's do
  4. Aug 21, 2014 at 8:59 PM
    nd4spdbh
    SoCal
    either 07 or 09 (i always forget) prerunners got zerk fittings also.
  5. Aug 22, 2014 at 1:45 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My 2012 does.
    This. ^^^
  6. Aug 22, 2014 at 4:14 AM
    Tommiet
    Tom
    Charlotte Area
    PreRunner
    Vote still seems to be out... But I did not find any on my 2013 (2WD) Pre-Runner.
  7. Aug 22, 2014 at 4:18 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    From what I've seen first hand with different manufacturers, they are not installing zerk fittings in any of the suspension components.
    My 2006 4x4 has zerks in the u-joint caps.
  8. Aug 22, 2014 at 4:58 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  9. Aug 22, 2014 at 5:40 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X2 ^ I wish they would of put them on the prerunners !!
  10. Aug 23, 2014 at 7:42 AM
    Tommiet
    Tom
    Charlotte Area
    PreRunner
    I did get back under my 2013 2WD Prerunner and it absolutely does not have zerks. I spun the shaft all the way around... none... nadda... zip.
  11. Aug 23, 2014 at 10:33 AM
    nd4spdbh
    SoCal
    id suggest you guys take another look at all 4 of the end caps of each u joint. and actually feel them... there should be the zerk nipple on one of them.
  12. Aug 24, 2014 at 6:16 AM
    Tommiet
    Tom
    Charlotte Area
    PreRunner
    Easy to check... but my 4-runner had the holes BUT you had to add your own zerks. Will manually spin and look, but I'm 100% sure, not zerks now.
  13. Aug 24, 2014 at 1:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    All I can say is at least my 2012 Prerunner has zerk fittings in the U Joints.
  14. Aug 24, 2014 at 4:46 PM
    TOY33
    TOY33 Well-Known Member
    Silver 14 DCSB PreRunner
    2014 prerunner .. no zerks, just checked.
  15. Aug 24, 2014 at 4:55 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    And I can say my 2012 4L prerunner does not; built mid-Dec 2011.
    Must be a production variation/change.
    I've heard if the propeller shaft replacement T-SB is performed, the new replacement one will have them.
  16. Aug 24, 2014 at 5:02 PM
    Tommiet
    Tom
    Charlotte Area
    PreRunner
    Right from the manual...
    Chassis lubrication - Propeller shafts Spider (4WD models and PreRunner with 2.7L 4-cylinder [2TR-FE] engine only)
    So my 6 cylinder does NOT have zerk fittings and that SUXS.
  17. Aug 24, 2014 at 5:22 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well that covers that. Mine is a Prerunner, 2.7 4 Cylinder.
    Another plus for the four bangers.
  18. Aug 24, 2014 at 5:30 PM
    OCNutty
    Northern, Va.
    So the T-SB for the clunk-thunk is starting to make sense...maybe we're a victim of accelerated wear w/o grease??? Depending upon the factory assembly for the ds, after installing bearing caps, there's no way to be certain they're packed with grease w/o fittings-could be almost dry at delivery.
    Anyway; I'm getting in line for a new drive shaft as I get that sensation; only problem is making sure it miss-behaves ... at the dealer...:confused: Got until 5/60k mi.
