u-joint ???
Discussion in 'Technical Chat' started by malteseowner, Sep 7, 2010.
  1. Sep 7, 2010 at 4:33 AM
    malteseowner
    malteseowner [OP] Member
    lisa
    ms.
    05 Tacoma
    flowmasters, dual exhaust
    hi guys,
    i have a 05 tacoma TRD 4.0 and i noticed a vibration at about between 5 to 10 MPH. took it to a tire place and he said my tires looked fine that i just needed to rotate and balance. about 2 days after that it got progressively worse, started really shaking at between 30 and 40 MPH. had my tires rotated and balanced. still the same problem. i got under the truck and looked at my u-joints, felt my drive shaft, and it seemed to be ok. any other way to check the u-joints?:notsure:
  2. Sep 7, 2010 at 4:44 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Maybe a CV joint is burned up. Check the rubber boots for tears and/or leaking grease. Also, have you been lubricating the driveshaft grease fittings throughout the truck's life?
  3. Sep 7, 2010 at 4:49 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    i didnt know i had CV joints, i thought that was only on front wheel drive vehicles, also the u-joints dont have grease fittings
  4. Sep 7, 2010 at 5:21 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    all my u-joints have grease fittings? is your truck a 4x4? i think i have 5 in total
  5. Sep 7, 2010 at 5:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW
    Lisa, we are going to need some more information to help you diagnose the issue.
    Do you feel the vibration in the steering or your seat?
    Is this a Pre-runner? Offroad or Sport TRD?
    Is it lifted?
    Mileage?
    Did it just suddenly start to happen then get worse?
  6. Sep 7, 2010 at 8:58 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    oh, sorry.. i feel the vibration in the seats and in the steering. it is a prerunner, it is not lifted, and the mileage is 81258. it is the off road TRD package.
    thank you
  7. Sep 7, 2010 at 8:59 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    its a 2 wheel drive, and yes it did suddenly start and then get worse
  8. Sep 7, 2010 at 9:01 AM
    larryde09
    Larry
    Boston, MA
    Not sure if they're actually called CV joints on these trucks, but there is certainly a rotating joint at each front wheel/suspension that separates it from the fixed front axle. The boots are located behind the brake dust shields and are held on by metal hose clamps.
  9. Sep 7, 2010 at 9:04 AM
    larryde09
    Larry
    Boston, MA
    Ah...a 2wd wouldn't have CV joints because there's no axle. I'm not familiar with 2wd tacoma's so I won't speculate further on its actual setup...
  10. Sep 7, 2010 at 9:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    They are called CV joints but she is a Pre. She doesn't have them.
  11. Sep 7, 2010 at 9:06 AM
    larryde09
    Larry
    Boston, MA
    On second thought, do you guys think it might be bad front wheel bearings?? Suspension components might be wearing out...just some thoughts.
  12. Sep 7, 2010 at 9:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Very well could be
  13. Sep 7, 2010 at 9:08 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    just wanted to say that i think all of you guys are GREAT
  14. Sep 8, 2010 at 9:19 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    Larry,
    i noticed the big write that you took the time to don on electrical issues. very good by the way !! and i wanted to ask you a question about my lights (running lights) on my 05 tacoma. both bulbs were burned out, i replaced them both. i thought it odd that they were both burned. but as soon as i turned them on again the both blew again.. any suggestions?
    thanks, lisa
  15. Sep 8, 2010 at 9:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you happen to touch the bulbs (the actual glass) with your fingers?
  16. Sep 8, 2010 at 9:25 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Naww, we pretty much all suck , but we'll try to help anyway !!! :D j/k
    Doubtful it's a U joint, have you considered the carrier (center) bearing ? 2 piece drive shaft correct ?
  17. Sep 8, 2010 at 9:28 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    no, i didnt touch the bulbs. i used to work at a auto parts place, so i know that the oil from your fingers will cause them to blow
  18. Sep 8, 2010 at 9:31 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    yep 2 piece drive shaft, i havent considered the center support bearing, it was just weird that it started all of the sudden. and it is getting worse. i was driving it yesterday trying to figure out if it was vibrating more in the steering or the seating area, and hell the whole truck felt like it was shaking...even the dash
  19. Sep 8, 2010 at 9:37 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well now its sounding more like an alignment issue , has it been checked recently ? Does it pull to one side or the other ? Tire condition ? Hit any curbs lately ?
  20. Sep 8, 2010 at 9:44 AM
    malteseowner
    lisa
    ms.
    05 Tacoma
    no, havent hit any curbs. just had the tires rotated and balanced, they said they looked fine. i guess i'll get a front end alignment and go from there. can they tell how bad it is out of alignment when they put it on the machine?
