U-Joints and Lift Replacement
Discussion in 'Georgia' started by DF4x4, Jul 29, 2019.
  1. Jul 29, 2019 at 8:14 AM
    DF4x4
    DF4x4 [OP] Active Member
    2015 Tacoma TRD Sport 4x4
    Hey guys, I am looking to see if anyone in this Georgia forum has experience replacing their u-joints? I have a vibrating when taking off and dealer is telling me it's either my u-joints or drive shaft needing to be re-balanced. Has anyone changed their u-joints themselves or is there anyone on here that does repairs? I am located in Cumming so somewhere within an hour drive would be an option. I also wanted to get input on possibly re-doing my lift. I have a 1.6" lift with Wheeler/Eibach coils / 3 Leaf Progressive AAL & Bilstein shocks all around. I now regret not going bigger and wanting to get input on best option to lift the truck again. Are the shocks the only parts I will probably be able to re-use?
  2. Jul 30, 2019 at 7:51 PM
    Seanb600
    Seanb600 Well-Known Member
    Sean
    Woodstock ga
    2019 TRD OR with real transmission
    Stock
    U-Joints are not a bad bad job some basic tools and a bench vise will do it look it up I’m sure there’s videos on it. My dad Taught me how to change U-joints when I was 8
    lynyrd3 and HappyGilmore like this.
  3. Jul 30, 2019 at 8:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yep. But as a first time exercise, having an experienced person look over your shoulder isn't a bad plan.
    Curious why? What function to gain by more lift? Or is it just a looks thing?
    Things get a bit risky (and more expensive) over 2.5". Lots-o-bucks, and work, for 1"
    lynyrd3 likes this.
  4. Jul 31, 2019 at 10:53 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Doraville Drive Lines & Springs did my u-joints and the u-joints on my son's 4Runner. The owner has the personality of a fish, but he does excellent work.
    DF4x4[OP] likes this.
  5. Aug 3, 2019 at 12:25 PM
    DF4x4
    Mainly for looks. The truck was a daily driver when I originally ordered the smaller lift. It’s now my secondary vehicle for when I need a truck and wouldn’t mind going a little bigger.
  6. Aug 3, 2019 at 12:28 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I would get that vibration issue sorted before you increase your lift, lifts tend to make vibrations much worse the higher you go. Check your carrier bearing too, if the bushing or bearing is bad it'll vibrate the driveline
    HappyGilmore likes this.
  7. Sep 4, 2019 at 7:02 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I can help and am located near Buford/Flowery Branch, so not a terrible drive from Cumming.
    I did my u-joints and center support (commonly referred to incorrectly as the carrier bearing) bearing just a little bit ago. For another $70, I'd highly recommend doing that at the same time as the u-joints. Since you are 4x4, you will use the same part numbers that I did (if you want OEM).
    Center support bearing: Spicer 5002007
    U-joints: Spicer 5-1330-1X (qty: 3)
    I think I paid $67 shipped (ebay) for the bearing and about $70 shipped (rockauto - has a 5% discount for TW members) for the u-joints.
    How many miles on your truck? Keep in mind, this may or may not fix your issue. I had a small vibe that was fixed when I replaced the leaf springs. The OEM pack with AAL was the culprit there.
