u joints keep wearing out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Strat, May 4, 2011.
  1. May 4, 2011 at 8:28 PM
    Strat
    Strat [OP] Member
    Idaho
    99 tacoma lifted
    I have had my tacoma for about 6 years now. put severa different lifts on it. after putting the lift on my u joints are wearing out really quick. I have replaced the front once and the back twice in the past two years. I do quite a bit of off roading but dont think they should be wearing out this quick. any suggestions on what is going on?
  2. May 4, 2011 at 8:30 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Have you ever greased them with a grease gun?
  3. May 4, 2011 at 8:34 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Bent drive shaft, happened on my pre-Tacoma and caused excessive wear. Hit it on a rock, could tell it was bent until I took it off and rolled it on a flat surface and could see that there was a slight bend.
  4. May 4, 2011 at 9:44 PM
    Strat
    Strat [OP] Member
    Idaho
    99 tacoma lifted
    ya i made sure the second time aroud to get the ones that i could grease. usually just do it when i change the oil. thanks though
  5. May 4, 2011 at 9:46 PM
    Strat
    Strat [OP] Member
    Idaho
    99 tacoma lifted
    i take it there is no easy fix to that? i will check it out. thanks for the tip
  6. May 5, 2011 at 5:39 PM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Junk yard
  7. May 6, 2011 at 1:27 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
  8. May 6, 2011 at 1:50 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    My money would be on pinion angle. Did the lift kit have shims in it? If not im pretty sure a parts store like ORD would be able to get them for fairly cheap. Usually a bent driveshaft can be felt, but sometimes not. The shaft could also be offbalance, but you would usually be able to feel that too.
    Also you should replace the joints in pairs. Sometimes the wear in the front will have enough slop to wear out the rear. You replace the front because it eventually goes out, but now the rear has slop and can wear out the front sooner.
  9. May 6, 2011 at 11:15 PM
    Strat
    Strat [OP] Member
    Idaho
    99 tacoma lifted
    huh makes sense. cant beleive i didn't think of that. I usually dont get the semptoms for a while after i change one. i will try replacing both and hopefully that will fix the problem
  10. May 6, 2011 at 11:20 PM
    Strat
    Strat [OP] Member
    Idaho
    99 tacoma lifted
    Thanks for all the info everybody. should have it up and running in time to take it up in the mountains and be the the first one to my favorite lake this spring
  11. May 7, 2011 at 12:34 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I think my U-joints are also going. Whats it sound like when it starts going?? I have this PING noise whenever i reverse and then go forward again.
  12. May 8, 2011 at 1:14 AM
    2008taco
    chris
    san diego
    Crawl under your truck and grab the drive shaft at the end. Try to wiggle it, twist it, etc. move to the other end and repeat. If there is a lot of wear in the U-joints replace them. If they are fine put the trany in neutral and twist the shaft to check the diff for wear. (my ranger has the same ping and this is the culprit) If its the joints replace em, if its the diff use your discretion. My ranger has done that since I got it, and i put over 20k on it with no problems, but my results might not be typical.
