U-joints Not lubed - reply from Toyota Care
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobrown14, Apr 2, 2016.
  1. Apr 4, 2016 at 6:03 PM
    #61
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    This is a great reminder for all of use to grease our u-joints at every oil change.
  2. Apr 4, 2016 at 6:05 PM
    #62
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    Try DELO ep#2. In all my years I've found nothing better, and in 35 yrs. of wrenching I've tried many.
    69TACO16 likes this.
  3. Apr 4, 2016 at 6:08 PM
    #63
    Tarheel54
    Tarheel54 Well-Known Member
    2016 Tocoma 4x4
    Thanks eldedo :cheers:
  4. Apr 4, 2016 at 6:09 PM
    #64
    RadMtn
    RadMtn Member
    Nashville TN
    '16 TRD OR
    King CoilOvers & Shocks SEMA TRD 17" Wheels 265/70/17 KO2's
    Is DELO the Chevron Grease?
  5. Apr 4, 2016 at 6:11 PM
    #65
    retired mech
    Tom
    St louis,Mo.
    There also is another thread on this. Check your U joints. 36 pages.
  6. Apr 4, 2016 at 6:14 PM
    #66
    retired mech
    Tom
    St louis,Mo.
    Yes Delo is Chevron. Delo is their top line of oil and grease.
  7. Apr 4, 2016 at 6:19 PM
    #67
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  8. Apr 4, 2016 at 6:51 PM
    #68
    Gus Gorilla
    Gus Gorilla Well-Known Member
    2016 White TRD OffRoad
    None...yet
    Just crawled under mine to mark my fluid check/fill points before going to the dealer tomorrow on trans shittyness. Fun-fact. It's a '16 DCSBOR auto, 4x, non-tow pkg. Has zerks on the fwd driveshaft. Does Not have zerks on the main shaft at any point. Wtf Toyota.
  9. Apr 4, 2016 at 6:54 PM
    #69
    retired mech
    Tom
    St louis,Mo.
    The main shaft has the zerks on the ends of the cap, not the center like the front.
    Blazingbluesport likes this.
  10. Apr 4, 2016 at 7:05 PM
    #70
    Gus Gorilla
    None...yet
    I had my beadie eyes and grubby fingers all over those things. No zerks. The fronts are on the flat face of the spider. The rears aren't there, aren't between any two bearing races, and aren't even on the shaft or yokes.
    Edit. I went to look again. They were on top. Put that on the "dumb things overlooked" list. That said, I touched them and they're all spotless. As in, not greasy. Cause for concern.
    renau001 likes this.
  11. Apr 4, 2016 at 7:50 PM
    #71
    retired mech
    Tom
    St louis,Mo.
    Check your U joints thread page 11. Great pics. of your zerk.
  12. Apr 5, 2016 at 12:11 PM
    #72
    bobrown14
    bobrown14 [OP] Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    ^^^ That, I told my service mgr at Toyota to "WRITE IT DOWN" lube and oil change every 5K... make it so grasshopper.
    This is the grease I use
    http://www.amazon.com/Valvoline-VV9...&redirect=true&ref_=oh_aui_detailpage_o00_s00
    To reply to the guy that said 10+ pumps was filling the hose... ummm I've lubed a u-joint or 2 in my day. Plus the hose didn't need to be re-filled after each joint was filled. All required 10+ pumps first one with the new lube took about 10-14 pumps same as the rest.
    That and there's a priming procedure when loading a grease gun that gets done PRIOR to touching any u-joint zirk fitting. So the gun was primed a head of time. By "primed" I mean making sure there's grease coming out the pump so I'm not pumping air into the u-joint that would require me to loosen the caps and/or remove the u-joint to get the air out.
  13. Apr 5, 2016 at 12:52 PM
    #73
    retired mech
    Tom
    St louis,Mo.
    You do not need to take the joint apart to get the air out. Just pump it full, the air will come out.
  14. Apr 5, 2016 at 4:29 PM
    #74
    WIDGIN9
    WIDGIN9 Well-Known Member
    Earth, I think.
    2016 MGM 4x4 Limited, 2001 Black 4x4 SR5 Doublecab
    NRA Life Member Sticker, Body Armor 4x4 Step Rail, Leer Trilogy Bed Cover
    Then again, the air in Philly could be a bit thicker than the air in St. Louis.
    What a ridiculous thread that's now filling up with grease salesman pushing their favorite brand. Who knew there were so many grease barons?
    I still prefer sweat from my female minions. Takes more effort than from the males but it's worth it. Gives my Tacoma a nicer smell going down the road.
  15. Apr 6, 2016 at 10:04 AM
    #75
    bobrown14
    Bob
    Philadelphia
    Gen 3
    .....could be the air between my ears not purging from the lube job my dealer gave me.
  16. Apr 6, 2016 at 11:48 PM
    #76
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    So what grease do we need to use? Moly, no moly? Lithium? Synthetic? I bought a grease gun but didn't know what grease to buy ...
    help plox
  17. Apr 7, 2016 at 4:48 AM
    #77
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    An nlg#2 that meets the Spicer spec.
    Lithium
    Lithium with moly
    Calcium sulphonate
    I'm using mystik jt6 hi temp.
    The only one I'll caution against is Lucas red n tacky; I believe that's a polyurea base.
  18. Apr 7, 2016 at 5:07 AM
    #78
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    thx spit. any of the 3 in bold are good for this application?
  19. Apr 7, 2016 at 5:44 AM
    #79
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Still better than what the factory "used"
  20. Apr 7, 2016 at 5:56 AM
    #80
    splitbolt
    NW Arkansas
