U joints tools
Discussion in '1st Gen. Tacomas (1995-2004)' started by shankyjones, Nov 9, 2022.
  1. Nov 9, 2022 at 10:01 PM
    shankyjones
    shankyjones [OP] Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Hey all, is there a specific tool used with a hammer to knock out ujoints for 1st gens?
    What do y'all typically use?
  2. Nov 9, 2022 at 10:10 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Balljoint c press things work good
  3. Nov 9, 2022 at 10:25 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  4. Nov 9, 2022 at 10:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A hammer and the right size socket if you don't want to buy any tools. You can find some utube vudeis on this. Personally, I use a C clamp and cups from a BJ kit.
  5. Nov 9, 2022 at 11:13 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    There is a video from Tom Woods where he does everything with a hammer and he does it fast. I doubt I would ever have such luck.
    Area51Runner likes this.
  6. Nov 10, 2022 at 12:13 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Yep, not so easy as it appears/sounds! I marred the hell out of one when trying to use the OTC Front End Svc Kit as well as a Powerbuilt U Joint C Press.
    That little tool mentioned earlier from OEMTools definitely makes it easier. I used a Dremel to remove any burs from pressing out the bearing cups and cleaned up the surface prior to installing. Also the C press from OEMTools makes install much easier. Once the spider bearing is in and the snap rings are in place, if the spider/trunnion has resistance when rotating some taps with a socket on each side will smooth it out.
    I thought I had screwed up big time but after a bit of trial and error the job is done.
    https://smile.amazon.com/dp/B07CHN44FL
    Kevins60 and Nessal[QUOTED] like this.
  7. Nov 10, 2022 at 12:41 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Hammer, old appropriate sized socket, block of oak with a hole drilled in it, Kroil, torch if it's really in there good.
    Lost in GA likes this.
  8. Nov 10, 2022 at 9:08 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Just something to be aware of- the yokes are tapered. The c-clamp style tools do not take that into consideration and can cause some issues when driving the caps back into the yoke.
    Timmy has a detailed video that covers this:
    https://youtu.be/6arj3PpT1p4
  9. Nov 10, 2022 at 9:37 AM
    Area51Runner
    Yeah, I watched his vid. Marred the crap out of it using the 3 jaw puller. Goes without saying, follow that route be extremely careful.
    Now that OEMTools remover or the Tiger version - much easier. It drives it out all the way clean and you can remove the bearing cup with little effort. Flip it over and do the opposite side. Rinse and repeat and done. YMMV of course but I'm satisfied with this route.
    The installer makes short work of pressing the cups back in. The magnetic end helps hold it in place. I also found that I could literally turn it by hand and press it back in, no ratchet needed and definitely no impact.
    Anyway, just another route to go. Cheers.
  10. Nov 10, 2022 at 7:04 PM
    O'Silver_Taco
    MD
    Only did mine couple years back.......
    ......but recently found these puppy's and was so easy to do......I'm gonna switch em out again....
    shankyjones[OP] likes this.
  11. Nov 10, 2022 at 7:34 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Why does Timmy the tool use butters as his thumbnail? I wonder if he has written permission for that.
  12. Nov 11, 2022 at 7:22 PM
    O'Silver_Taco
    MD
    taco survival kit......
    Diablo169 likes this.
  13. Nov 11, 2022 at 8:55 PM
    Nessal
    Texas/Bay Area
    Is that the smallest ujoint press they sell? I believe that is the light truck version?
  14. Nov 11, 2022 at 9:23 PM
    Area51Runner
    Nessal[QUOTED] likes this.
  15. Nov 11, 2022 at 9:35 PM
    O'Silver_Taco
    MD
    I believe they make one size up.....black ones....
    they sell for a lot more.....like $110 and up.....
    Look for harbor freight or ebay knockoffs for around $30....
    .....just a matter of time.......
  16. Nov 11, 2022 at 9:46 PM
    O'Silver_Taco
    MD
    What I like about the tool....allows to precision press cups back in so they dont bind....
    Hundred years ago I did a chevy van.....UJ failed again within couple years...thats probably why.....
    '75 G series.....
    Nessal likes this.
  17. Nov 12, 2022 at 6:59 PM
    Lost in GA
    Lost in GA Member
    GA USA
    2003 Tacoma DLX SR5 V6 TRD Ext Cab 4x4, stock
    I've done mine twice in the past 9-months...my taco is eating u-joints. Anyways, I used two screwdrivers to force out the c-clips, tapped with a ball peen hammer, then the first time I pressed in the u-joints and this last time I tapped them in with a socket and hammer. Getting the shaft off is the hardest part. I replaced on u-joint with the drive shaft on the truck...just laid a piece of plywood on the ground for the yoke to lay on.
    Those clips are on the inside of the yoke, and I use two flat-head screwdrivers, holding both in one hand, and tap both of them at the same time with the hammer. They pop out fairly easily. If I cradled the yoke on a block of wood it might be easier, but i never expected to have to replace them so frequently.
  18. Nov 12, 2022 at 7:19 PM
    O'Silver_Taco
    MD
    I've had really good luck on a number of things.....just sliding together without a press.....
    by sticking the appropriate new part or seal in freezer for 24hr prior......
    Rear axle bearing and inner seal both slipped right in......
  19. Nov 12, 2022 at 7:45 PM
    cone of shame
    cone of shame Member
    Denver
    02 TRD NY -> AK -> CO
    Salt spray and rock chips.
    For removal, a hammer and wooden blocks worked fine for me. I bolted the flange to some angle iron to help hold it steady.
    For reassembly I used the C-clamp style Autozone rental tool. Didn't want to risk it on the 20T press in case it dropped a needle and I wouldn't be able to feel it bind up.
    I did all four this way, no trouble once I got the hang of it.
    T4ioI536dBdNRq_RzLsrkIbOeocInzQqaWntXy2h_e487a649fd530988c28de10d106d39f0708c4430.jpg
  20. Nov 12, 2022 at 8:00 PM
    O'Silver_Taco
    MD
    Vast years of doing UJ's.......water gets in em......hot needles rust....then disintegrate...in double time....
    Flushing out with the zerts once a year is best way......
    You say.....the four channels dont flush/flow evenly......or some any at all....flushing only couple channels instead of all 4 corners....
    You have to micro torch the slower channels to help em along while pumping grease.....till all four flush......not rocket science.....
