U joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Feb 20, 2016.
  1. Feb 20, 2016 at 11:14 AM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    So my center support bearing is bad (carrier bearing) and I was also going to replace any u joints while I have that section of shaft out.
    Are U joints "one size fit all" or do I need a specific size? Are there different sizes throughout the shaft?
    Any help would be great, thanks guys!
  2. Feb 20, 2016 at 11:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Couple threads for you, I assume its on your 2011 you have as your vehicle? I went to NAPA and had them look the ujoint up. They said I needed 3 but on my 2000 Tacoma I only needed 2 so depends what yours is set up like. The cardan joint is a whole different thing so I just ended up changing the ujoint by the trans and by the rear axle and greased the cardan joint. I already had to take of the driveshaft to replace my center bearing so I just did the U-joints while it was out. You can go to Autozone and rent the ball joint puller and you can replace your ujoints with that.
    the u-joints were the same part# for the two I had to replace.
    https://www.tacomaworld.com/threads/how-to-replacing-carrier-bearing.260283/
    https://www.tacomaworld.com/threads...g-carrier-bearing.387484/page-2#post-11801106
    MTopp likes this.
  3. Feb 20, 2016 at 12:30 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The U-joints on our generation of taco are all the same size. Spicer 1330 series is stock, although they cost 4 times as much from the dealer as from the parts store. For some reason, Prerunners are not greaseable, however I would advise upgrading to a serviceable joint if that's the case. Napa carries an off brand, be warned I had one grenade on me. It's not worth saving a few bucks to go with the house brand, get genuine Spicer!
  4. Feb 21, 2016 at 5:47 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    U joints are like tires, you get what you pay for. I'd research which brand is better and spend the money on a good one. You can physically see the difference between a a good and a cheap one, and don't let a guarentee fool you. Like Tommy boy said "I can take a dump in a box and mark it guaranteed, I've got the time".
    CroResident likes this.
  5. Feb 21, 2016 at 10:08 AM
    jsnm23
    2011 mgm TRD OR 4x4
    I bought Moog joints. Any good?
  6. Feb 21, 2016 at 10:23 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yeah they are fine, as long as they have grease zerks and you give them a shot of grease once a year, they will last a long time.
    TacoTuesday!! likes this.
  7. Feb 21, 2016 at 2:23 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    I have lost all faith in MOOG components. A buddy replaced his front end parts on an all stock Dodge 2500 using all MOOG parts, it drove horribly and was all over the road. Two alignments later, he pulled all of their ball joints back off and replaced them, problem solved! I hope their u joints are better. I did use their parts back in the day and they were quality, I'm not sure what happened but I have heard the same since.
    MTopp, TacoTuesday!! and landphil like this.
  8. Feb 21, 2016 at 4:32 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'd return the Moogs and get some Spicers.
    MTopp, hotrod53 and llibrm like this.
  9. Feb 21, 2016 at 4:55 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    After what I and others here have gone through with moog lca bushings I'm done with them.
    MTopp likes this.
  10. Feb 21, 2016 at 5:02 PM
    jsnm23
    2011 mgm TRD OR 4x4
    Oh great!:annoyed:
  11. Feb 21, 2016 at 5:34 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I would recommend the Spicer 5-1330-1X. I called Spicer to ask what the differece was between 5-213X and 5-1330-1X. Both will fit and both are greasable. The 5-213X has the zerk fitting on the body and double seals, the 5-1330-1X has the zerk located on the end of one of the caps and has triple seals. The 5-1330-1X is beefier and a better choice for severe use such as offroad. There is a non greasable version of the 5-1330-1X. It's part number is 5-1330X. I was able to purchase 3 of the Spicer 5-1330-1X on Amazon for a little under $75 with free shipping.
  12. Feb 21, 2016 at 6:35 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    The spicer is definitely the way to go.
  13. Feb 21, 2016 at 6:44 PM
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    I just replaced all three U joints with Spicer 1330-1x and replaced carrier bearing with OEM one from stealership. Really smooth now
    jsnm23[OP] likes this.
  14. Feb 21, 2016 at 8:48 PM
    jsnm23
    2011 mgm TRD OR 4x4
    OK. Maybe I'll return the moogs and get Spicer. I really hope replacing these parts will solve my vibration / shudder problem. I'm scared it may be a tranny issue:eek:
  15. Feb 21, 2016 at 9:26 PM
    Ahougland89
    Anthony
    Orting, Washington
    Ya dude you might have to order online but they are easy to get. Most auto parts stores don't have them. I went to a special driveline shop for mine and he was only going to charge 17 bucks per U joint in labor and 20 bucks for a carrier bearing to install but you have to bring the drive shaft into them. I thought that was a good deal but i ended up doing it myself. Im sure it will fix vibration
  16. Feb 21, 2016 at 9:29 PM
    jsnm23
    2011 mgm TRD OR 4x4
    Already ordered: Amazon 25 a piece shipped
  17. Feb 21, 2016 at 9:54 PM
    Taco'09
    Taco'09 Well-Known Member
    ^^^ Same here. A long time ago I worked at a parts jobber and anyone who wanted the best asked for Moog. Not anymore. What happened? They bellied up and the name and few assets were purchased by Federal Mogul. So now they try to sell horrible parts based on laurels of Moog from long ago. Their stuff now is some of the worst junk going IMHO. But for the OP, in this age of reboxing, before you return them take a peek to see of you may have received Spicer. Look for 1330 on the parts and maybe the Spicer name, you never know...
  18. Feb 21, 2016 at 9:59 PM
    jsnm23
    2011 mgm TRD OR 4x4
    I ordered them online. I just contacted the seller and told him to cancel my order of shit in a box and he kindly refunded my $. I then went to Amazon and ordered Spicer.
  19. Feb 21, 2016 at 10:00 PM
    Ahougland89
    Anthony
    Orting, Washington
    Are you doing the carrier bearing?
  20. Feb 21, 2016 at 10:05 PM
    jsnm23
    2011 mgm TRD OR 4x4
    Yes
