U joints
Discussion in 'Toyota Trucks & SUVs' started by TXRailroads73, Oct 7, 2018.
  1. Oct 7, 2018 at 9:21 AM
    TXRailroads73
    TXRailroads73 [OP] RÖCKIN'ROLLIN',BEER,YOTAS,TACÖCRÜE,MAX/GEMMA
    Adam
    The Lone Star State, RGV, TEXAS
    '23 TRD PRO
    None all stock
    Any one have any knowledge for the U joints for the 4wd shaft on T100 or similar chassis, does the front sway bar need to be removed? Also the rear crossmember for transfer case is anything holding transfer case up? Almost removed all 8 bolts holding and I realized there doesn't seem to be anything holding transfer case up, so I'll assume I need a jack or jack stands for it??? Any knowledge greatly appreciated
  2. Oct 7, 2018 at 9:28 AM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Ya kinda started out right in the middle of things here perhaps a little back ground of what your doing will help everyone understand what you are setting out to do because from the post we can only guess at things so be generous on the details and I'm sure that there are folks here that will know.
  3. Oct 7, 2018 at 9:58 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    I just changed our all u joint y on main drive line, now I'm wanting to change out ones for the 4wd shaft, ther is a crossmember what looks to be like it is supporting the 4wd transfer case at the bottom, what I'm wanting to know is there any anything else holding the TC from above? The CM has 4 17mm bolts at each end I was down to one bolt each side when I realized the TC might fall down, so I'm assuming I need to support it with a jack??? And at the front of the 4wd shaft ther is a front sway bar, does this need to be removed?
  4. Oct 8, 2018 at 11:40 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
