UBJ Blown and outer tire wear. OME 881 & 5100. What gives? (Was Front End & Brake Conundrum.)
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjhenks, Jun 21, 2019.
  1. Jul 5, 2019 at 11:54 PM
    #41
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It's possible for iy to be drawing microscopic bubbles past a wheel cylinder seal. It should have cleared up eventually. Try putting a 1 foot long piece of vacuum hose over the bleeder. Crack the bleeder open and let it gravity bleed and see if it clears up.
    You will get alot of air noise when bleeding the brakes. This is do to the pedal moving so much farther then normal. It has to pull air into the inside of the chamber.
    It will be a little soft then build up solid. If your rear brakes are out of adjustment it will take longer to get solid. Also the tundra upgrade makes the pedal A little lower.
    You can do rears without bleeding the brakes if you don't change wheel cylinders. I recommend you change them when doing the brakes.
  2. Jul 7, 2019 at 9:32 AM
    #42
    mjhenks
    mjhenks [OP] Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Alignment redone. Not much of a change and after driving some more the problem is still there. Really no change.
    It will take some time to see if my front tires are still feathering
    Frustrating
    My next move is to install a plug to cut off the rear hydraulics completely to rule them out.
    What else???
    Kiloyard likes this.
  3. Jul 7, 2019 at 9:53 AM
    #43
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  4. Jul 7, 2019 at 2:12 PM
    #44
    mechanicjon
    Jon
    Scottsdale Arizona
    Using some hoses to bypass ABS Controller.
  5. Jul 7, 2019 at 2:39 PM
    #45
    mechanicjon
    Jon
    Scottsdale Arizona
    Did you ever get the rear one to bleed clear fluid?
  6. Jul 8, 2019 at 7:09 AM
    #46
    mjhenks
    So.Cal
    Spend yesterday working on my other project.
    New alignment done Saturday. I love how they did not even bother to look at the rear. I pointed out the fethering to them though on the fronts.
    Honestly i have not driven it enough after the alignment to asses any change.
    Thanks @Dirty Pool I am not there yet. This is probably my truck just complaining for all the 4x4 work i did the last 6 months.
    @mechanicjon.
    - Regarding bleeding not yet but we did spend time bleeding brakes on our VW and got similar results so i think it is the hose sucking air from the side. Will bleed once more time though and change out the hose.
    - Regarding bypassing the ABS. I thought i already ruled that out by pulling the large connector at the brake manifold in the engine bay. I also was prepared to pull the ABS fuse if anything went weird on my trip but nothing went any weirder than it already is. Do you stil suspect ABS here?
    cruiserguy likes this.
  7. Jul 8, 2019 at 7:19 AM
    #47
    mechanicjon
    Jon
    Scottsdale Arizona
    I've seen the valves inside cause a problem before. Although vert rare. Usually going out and making the abs cycle with some abs stops will clear it up.
  8. Jul 8, 2019 at 7:20 AM
    #48
    mechanicjon
    Jon
    Scottsdale Arizona
    Nice VW!
  9. Jul 8, 2019 at 7:37 AM
    #49
    mjhenks
    So.Cal
    Thanks. My other car addiction. Have worked on them now for 30 years.
    A few others i have owned. Some have been in magazines and books. Some were just nice to own. Those were the days. Carefree when i could work on cars all day long. :)
    Anyways....
    "Thank you to our sponsor and this trip down memory lane."
    "Now back to our regularly scheduled program."
    Problem solving...
  10. Jul 8, 2019 at 2:36 PM
    #50
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    aww man, I always wanted a VW beetle. knew someone back in college had one, so cool
  11. Jul 12, 2019 at 7:14 AM
    #51
    mjhenks
    So.Cal
    Finally got to drive my truck last night. My son has been driving it this week. His report was that the pull to the right was still there. After driving i agree but it is different.
    It was pulling right and then the wheel would jerk left. Now it seems to be just a pull right. Only change so far is the alignment.
    I have a brake line isolator coming. Next step is to remove the rear brakes from the system to see if that changes things.
    mechanicjon likes this.
  12. Jul 16, 2019 at 8:49 PM
    #52
    mjhenks
    So.Cal
    Had a little time today to look at the truck. What was bothering me was still the feathering of the front wheels and the rear brakes. I do have a brake block off plate now but no time. Here is what i did.
    Jacked up rear of truck. Put into drive and hit brakes. Both brakes appear to engage at same time but there is no load so i do not think it is a real test. I also pushed and pulled the rear wheels. Slight axial play on drivers side. None one passenger. Does this mean bearings?
    Jacked up the front end and did the same push pull with engine on being VERY careful. Had my son hold the steering wheel and brakes. This was interesting. With the wheels straight things seem fine. As i turn the wheel either way to the extreme the inside turning wheel gets lose. Very lose. As the tie rod pulls the wheel all the way in it is like it cams over on itself and cannot keep the wheel stable. I get like 1/2" of wobble left/right. Is that right? Remember i have all new tie rods and ball joints.
    Also what do you look for in a bad steering rack?
    Thanks
  13. Jul 17, 2019 at 12:42 AM
    #53
    mechanicjon
    Jon
    Scottsdale Arizona
    Were's the looseness coming from? There shouldn't be any play in the rear bearings, in and out or up and down. What kind of LCA bushing did you use?
  14. Jul 17, 2019 at 3:29 AM
    #54
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Great VW!
  15. Jul 17, 2019 at 3:30 AM
    #55
    cruiserguy
    Elijah
    SEKS
    Yeah me too
  16. Jul 17, 2019 at 7:32 AM
    #56
    mjhenks
    So.Cal
    @mechanicjon
    The rear drivers side wheel has in/out play when you push/pull axially by hand. Very little but i have been noticing a clunk coming from the rear when i go over speed bumps. Thought it was suspension but nothing seems to be loose.
    The UCA's are MOOG. The LCA bushings i do not know. These two are the only work i did not do personally. They were done the day before leaving on vacation in a "Bend over and take it" moment with a company i will never use again. They also replaced the LCA adjusters.
    It is weird. When wheels are straight no left/right movement. As you turn sharp either way the inner turning wheel gets more and more loose (left/right) I'll take a picture but as you turn to the limit of the steering the tie rod ends start to take on a higher and higher angle from the steering rack. That angle closes in on the lower ball joint arm where the tie rod end connects and at the limit the geometry is such that the wheel can move left/right as the ball joint ends pivot on the steering rack. It is geometrically not mechanically strong at this position which is why i wonder if it is a problem or normal. I can see the how this would cause feathering but cannot see what would cause it other than a bad steering rack maybe?
    As a reminder i have replaced:
    UBJ. (ProForged)
    LBJ. (ProForged)
    Both Tie rod ends. (MOOG.)
    Steering rack bushings. (Urethane form 4 wheel parts.)
    Wheel bearings. (Koyo)
    UCA. (MOOG)
    LCA bushings and adjusters. (Unknown)
    MC rebuild (Toyota)
    Front calipers replaced. (Tundra rebuild by Napa)
    F/R flexible lines (4 wheel parts)
    Brakes have been bleed 3 times.
    Alignment done 3 times.
    I will grab an image of the geometery and try to show the motion i am seeing but do either the front wheel or rear wheel items seem right?
  17. Jul 17, 2019 at 7:33 AM
    #57
    mjhenks
    So.Cal
    Thanks. My daily driver it seems now days.
    cruiserguy[QUOTED] likes this.
  18. Jul 17, 2019 at 7:41 AM
    #58
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Sway bar end links? Pretty much the only thing not on that list and they’re cheap enough. Sway bar helps even out loading on front shocks, so if one is work it could result in some weird unevenness.
  19. Jul 17, 2019 at 9:38 AM
    #59
    mechanicjon
    Jon
    Scottsdale Arizona
    All that was done after the pull started and no change after repair? Rotated tires?
  20. Jul 17, 2019 at 10:30 AM
    #60
    mjhenks
    So.Cal
    To the best of my memory the pull started after or just before i replaced the front spindles. Between time = 0 and time = 6 months. (See below) I am going to go out on a limb and say it has been getting worse or i have been paying attention more. Probably a little of both.
    I have rotate tires a few times. I have 5 identical tires/rims so i rotate through my spare too.
    Timeline looks like this:
    Time =0. New tires. Don't recall a pull.
    Time = 1 week. New UCA, LCA Bushings and LCA adjusters plus alignment. Don't recall a pull but it started somewhere between here and T=6 months. Obviously it was not terrible.
    Time = 1 month. New rear springs and 5100 shocks. Alignment & rotate tires.
    Time = 6 months. 4WD Spindle w/ new bearings on donor spindle and hubs. New UBJ & LBJ. Alignment done. For sure pulling now.
    Time = 10 Months. Steering rack bushings, Outer Tie rod ends + alignment. Pulling.
    Time = 10.2 Months. Inner Tie rod ends + alignment. Pulling.
    Time = 12 Months. Tundra brake upgrade w/ new flexible lines F/R. Bleed brakes & rotate tires. Pulling.
    Time = 12.5 Months. Master Cylinder Rebuild. Bleed brakes. Pulling and now i notice tire feathering.
    Time = 13 Months. Front 881 coils and 5100 shocks. Alignment. Pulling.
    Time = 14 Months. Alignment. Still Pulling.
    I really, really appreciate your help Jon. I do not think i am a bad mechanic and can usually figure things out. Part of me wants this to be stupid silly and part of me wants to to be a real sneaky issue. I am not sure what there left to replace or test. My list:
    - Photograph front steering limit play to see if that is normal.
    - Say bar ends. Easy to do so OK.
    - Remove rear hydraulic brakes from system with plug and see if things change.
    - Replace rear wheel bearings since it is likely one is going out. Probably replace rear brake pads at same time.
    - Replace steering rack.
    After that i think i have to start thinking about reverting back few steps and:
    - Remove Tundra brakes and go back to Tacoma. I know for sure this did not change things but...
    - Remove 4WD spindles and go back to 2WD. Keep rest of 4WD in there other than front drive axles.
    Any other ideas? What am i missing?
