UCA and Axle issues after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foxman1218, Jul 14, 2014.
  1. Jul 14, 2014 at 9:49 PM
    Foxman1218
    Foxman1218 [OP] Well-Known Member
    Batavia, IL
    2017 TRD Sport
    Method Race Wheels, 2.5" lift 275/70/17 BFG AT's
    first off Im new here to the forum but a long searcher on this website. I recently installed a 3" toytec lift on my 07 Tacoma 4x4 Trd Offroad and Total Chaos UCA's. I have 885 springs on the truck and bilstein 5100's all around with the front being set at 1.75". So thats a total of about 4.75" up front. Im having an issue where my uca's seem to be at/near full droop and on the passenger side uni-ball is actually hitting the control arm, left nice mark in it from hitting.
    any ideas on how to resolve this?
    lower the 5100's to .85" or 0"?
    anybody else have a similar setup without issues?
    Ive tried searching for an answer to my problem but cant find an exact answer that helps, but i did notice that i seem to be the only one 4x4 with 3" lift coils and 5100's set at 1.75" which leads me to believe the 5100's may be my issue
    Thanks in advance
  2. Jul 14, 2014 at 9:51 PM
    Foxman1218
    Batavia, IL
    2017 TRD Sport
  3. Jul 15, 2014 at 3:49 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    4.75 is way to high for a 4x4 lift.once you go past 3 inches. You need a drop bracket lift. Should check your angle of your cv axles. If you drop it down to 3 inch or lower, it will correct the problem you are having
  4. Jul 15, 2014 at 3:55 AM
    Foxman1218
    Batavia, IL
    2017 TRD Sport
    Thanks for the info. Forgot to mention that I have a 1" differential drop on my truck as well. and the cv angles are way replaced the passenger side twice and now have to do the driver side.
    Do you think I could get away with setting the 5100's to .85" or have to 0 them out?
    I ask bc I have 285/75/16 on my truck
  5. Jul 15, 2014 at 3:56 AM
    Large
    Large Red
    Set the 5100s at 0, problem fixed
  6. Jul 15, 2014 at 4:03 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    That's your answer^^
    But even with a one inch diff drop. At 4.75 inchs that's why you are changing cv so often.
    I have 70k on my truck and never replaced my axles. Then again I'm 6 inch lift with a drop bracket
  7. Jul 15, 2014 at 4:16 AM
    Foxman1218
    Batavia, IL
    2017 TRD Sport
    Well I know what I'm doing this week. Thanks for the info
  8. Jul 15, 2014 at 6:20 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Yeah way to high for 4x4 I have mine at 0 with 885s and all pro standards in the rear running 285 70s and that's perfect any higher get a drop bracket or a 2 wheel drive
  9. Jul 15, 2014 at 6:25 AM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    Dont preload your OME coils. Go back to 0 for sure.
    What do you have in the back for suspension?
  10. Jul 15, 2014 at 6:32 AM
    Foxman1218
    Batavia, IL
    2017 TRD Sport
    I have the tsb springs with 1.5" AAL.
    Good to know that your able to clear that tire size. I'm not opposed to doing some trimming if need be
