UCA ball joint replacement help
Discussion in 'Suspension' started by Fiend13, Aug 24, 2014.
  1. Aug 24, 2014 at 12:51 PM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Turns out both ball joints on my Light Racing UCA's are bad. I found the replacement ball joints but before I order them, how do you change them out? Just take the tire off and disconnect the ball joint from the spindle or is there more to it? I installed my lift myself so I have mechanical experience, just never had to swap ball joints out before and I figured it would give me something to do one weekend.
  2. Dec 9, 2014 at 1:44 PM
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
    I would like to know this as well. My LR UCA ball joints are a bit loose and need to be replaced. Is it as simple as jacking up the frame, taking the tire out, disconnect the old and reconnect the new ball joint? How long should I expect it to take? Since geometry shouldn't change (just swapping the BJ), do I really need an alignment?
  3. Dec 9, 2014 at 1:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    IIRC , Fiend did the SPC / LR UCA warranty swap
  4. Dec 9, 2014 at 2:22 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just disconnect the ball-joint from the knuckle, carefully mark the camber/caster positions and then loosen the one nut attaching the joint to the arm. I would recommend pre-packing the boots on the new ones with quality grease before installing them.
  5. Dec 9, 2014 at 2:27 PM
    Imageoguy
    2012 DCLB SR5
    Did he swap the complete UCA or just the ball joints? I called SPC yesterday and they will send me the replacement BJ's free of charge. I have about 25K miles on mine and they are pretty loose.
  6. Dec 9, 2014 at 2:28 PM
    Fiend13
    Chad
    I didn't do the warranty swap since I had the UCA's for a few years. The warranty I had was the extended warranty for when I bought the truck and that covered my LCA BJ's.
    This is what I did. It literally took longer to jack the truck up and get the tire off and then put the tire back on and downjack than it was to change the BJ
  7. Dec 9, 2014 at 2:29 PM
    Fiend13
    Chad
    Just the ball joints
  8. Dec 9, 2014 at 2:41 PM
    OZ-T
    Peter North
    British Columbia
    My bad
  9. Dec 9, 2014 at 2:44 PM
    Imageoguy
    2012 DCLB SR5
    Thanks guys! Now I just have to wait for parts and above freezing temps.
  10. Dec 9, 2014 at 2:47 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    What kind would you put in yours? Fixin to be installing a new set on my 08 and would prefer to not play the warranty swap after only 25k. Never had any issues with the ones on the 05 but they didn't see much offroad and this new set won't be doing much offroad stuff either.
