Uca ball joints
Discussion in 'Suspension' started by Oowen, Sep 20, 2012.
  1. Sep 20, 2012 at 6:03 PM
    Oowen
    Oowen [OP] Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
    My father recently ordered camburg's ball joint uca.
    Where can I find either the Toyota ball joint part number, or a good aftermarket one that will fit.
    Thanks
  2. Sep 21, 2012 at 6:35 PM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
    Bump.
  3. Sep 21, 2012 at 6:56 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    whatchu talkin about Owen??????????
    lol u mean the lower ball joint. i recommend oem.... peerly cuz im a toyota mechanic and i have seen aftermarket joint fail.
  4. Sep 22, 2012 at 1:17 PM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
    What goes in the uca then?
  5. Sep 22, 2012 at 3:56 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    im so confused.... u bught ucas without ball joints?
  6. Sep 22, 2012 at 5:48 PM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
  7. Sep 22, 2012 at 6:10 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ok sou either use ur pre existing ball joint or u buy new ones...
  8. Sep 22, 2012 at 6:11 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Exactly the question he asked in the OP
    Lol
  9. Sep 22, 2012 at 6:14 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    it was not nearly as clear as that^
    if u need the part number for oem call ur dealer
  10. Sep 23, 2012 at 8:01 AM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
    Ok thanks
  11. Sep 24, 2012 at 6:53 PM
    VE7OSR
    VE7OSR 'interfering with Natural Selection since 1990'
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, PIAA bulbs, LED bulbs all around, modified flasher unit for LEDs Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. Metal Tech Sliders w/ kickout and dimple die filler plates. swaybar relocate blocks (build my own)
    Toyota OEM does not sell the UCA Ball joint, you have to buy the entire UCA.
    The Camburg UCA you describe is designed to accept the factory ball joint (BJ) after you remove the BJ from your existing arms.
    There are aftermarket Moog units available, but Camburg does not recommend them. Huh? Why would you not design your arms to accept aftermarket BJ replacements???
    I measured .025" clearance between the Moog units OD, and the Camburg arm ID, did research on BJ design, and determined this is the design minimum required, and therefore should work. For added clearance I heated up my camburg arms in the oven to 400F, and put the ball joints in the freezer, to gain some additional clearance of about .004-.005", expecting to rapidly install the BJ with a rented BJ removal/install C-clamp tool. That did not work out for me, as I did not have a decent vise to hold the install tool, but in theory should still work. I did get them installed at room temperature, and I noticed it is super critical to get the BJ to press in absolutely perpendicular to the bore. In my case, the one unit went in a bit crooked, and it broke a small portion of the camburg arm on the exit side of the bore. It won't affect its usability, as there was plenty of metal holding the BJ in place, but I learned the lesson.
    Camburg could also have chamfered the exit side of the bore diameter to prevent this as well. The entry side is chamfered to allow you to line up the start.
  12. Sep 25, 2012 at 2:26 PM
    Oowen
    Owen
    Elko, NV
    '09 Offroad
    :)Wow thanks for the info. I just purchased some from car quest
    Thanks for all the help
