UCA bolt came out...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolfman00, Dec 2, 2011.
  1. Dec 2, 2011 at 10:04 PM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Annapolis
    '17 BRM SR manual 4x4
    stock
    so, truck is at the dealership because the nut fell off the UCA, and the bolt started backing out to the point where my drivers side UCA almost came off. (until it hit the sheetmetal and stopped). I had bilsteins put on, but the dealership is saying they are not obligated to cover it since they didnt install them. They claim its the mechainics fault because he installed the coilovers and touched the UCAs. I know its not because he never touched the UCAs with the bilstein install (I was there). So toyota says they dont have to cover it. I call BS.
    What do I do? I'm caught in the middle.
    Any advice how to approach this is good.
  2. Dec 2, 2011 at 10:06 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    sounds like a dealership for sure. they tried to tell me that my sound system wires were interfering with my airbag sensors in the seat. they told me that they had cleared the code but the light will come back on if i dont move my wires.
    Never moved my wires and the light never came on. Got charged 50 bucks for that little visit. my theory. there was a loose plug somewhere and they got pissed and wanted money.
  3. Dec 2, 2011 at 10:10 PM
    HIYota
    HIYota Well-Known Member
    Angel
    O'Fallon, IL originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I'm guessing you don't have aftermarket UCAs. Best I can think to do is explain the install process for the new shocks and point out that there was no need to mess with the stock UCAs. Other than that I'd either find another dealer or put in a formal complaint. It's not like this is a hard fix for the dealer either. I mean it's replacing the nut and placing the proper torque when putting it on. Dealers...pain in the ass.
  4. Dec 3, 2011 at 4:35 AM
    wolfman00
    matt
    Annapolis
    stock
    Honestly, if they were just to give me the nut, we would be fine.
    Im lucky I caught it, because the uca was riding on 1/2" of thread. Oh, they are stock UCAs too.
    I explained to the mechanic how we did it and didnt touch the UCAs, but because they were not there to see it...and insinuated that I was lying. That pissed me off the most.
  5. Dec 3, 2011 at 1:08 PM
    HIYota
    Angel
    At this point I'd just get the but and do it yourself. It's a good thing that the bolt doesn't come out easily. I had to pry the sheet metal forward and even grind it down just to get it out.
  6. Dec 3, 2011 at 2:33 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    The pin that keeps it from turning wasnt in there?
  7. Dec 3, 2011 at 2:37 PM
    wolfman00
    matt
    Annapolis
    stock
    yeah, at this point I just want the nut so I can fix it myself.
    Here is the kicker- since I know that nobody touched that bolt...what other bolts on the front end are loose from the factory? food for thought.
  8. Dec 3, 2011 at 4:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I'm suprised the UCA bolt backed out uphill on it's own
  9. Dec 3, 2011 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    There is no retainer pin.
    X2.
  10. Dec 3, 2011 at 5:09 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    I think it's the top long bolt & nut. The bolt will not come out it will hit, I cut mine off then installed newones from the bottom.
  11. Dec 3, 2011 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I know which one it is, Thanks.
  12. Dec 3, 2011 at 5:15 PM
    OZ-T
    Peter North
    British Columbia
    It's the long one in the top that's hard to get out .
  13. Dec 3, 2011 at 5:18 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    If you have a torque wrench and a socket set take a look at the FSM and find the torque specs and check the stuff yourself
  14. Dec 3, 2011 at 5:27 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Banned because of this comment? Owned noobs
  15. Dec 3, 2011 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh no....He was banned as he requested.
  16. Dec 3, 2011 at 5:38 PM
    Mr.Ed
    Wilbur's Barn
    I think Chris4x4 had a thread that had the torque spec. for the upper control arm bolt & the other ones. I think it was from 2009. It was a spring removal thread I think.
  17. Dec 3, 2011 at 5:39 PM
    OZ-T
    Peter North
    British Columbia
    Horse hockey
  18. Dec 3, 2011 at 9:23 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    bout 85 ft lbs IIRC
  19. Dec 3, 2011 at 10:07 PM
    wolfman00
    matt
    Annapolis
    stock
    oh ok cool, I am just going to go through everything in the front when i get it back and check the torque on everything.
    I should have taken a photo of it, it was freakin weird. I should add- i was taking it in on monday anyway for my 3rd AC motor.
  20. Dec 3, 2011 at 10:17 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    X3, the nut must have been missing for a while
