UCA Choices Explained
Discussion in 'Suspension' started by dziner, Dec 21, 2016.
  1. Dec 21, 2016 at 7:41 AM
    dziner
    dziner [OP] Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    Looking at suspension lifts is difficult enough, comparing front and rear shock types and leafs. Add in UCA options and my head is spinning. Can anyone give details on the pros/cons of the UCA choices out there for the Toyota Tacoma? Selecting a UCA is a large chunk of the cost of doing a suspension lift. I really have no education behind why to select one over another if I were to piece together a lift for my truck, or to even select from an option given from a kit offered by someone like Headstrong Off-Road.
    Can anyone explain the differences of these UCA's? Why would one be selected over another?
    • SPC Light Racing
    • Camburg Uniball
    • Camburg Balljoint
    • Total Chaos
    • Total Chaos Uniball
    • Icon Uniball Billet
    • Icon Uniball Tubular
    • All-Pro
    • Fabtech
    • Baja Kits
    • JBA
    • Dirt King
  2. Dec 21, 2016 at 7:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It varies depending on what your needs are. Are you looking to just get back into alignment? Or looking for that extra 1" of down travel?
    ChadsPride likes this.
  3. Dec 21, 2016 at 7:51 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    We have a UCA as well!
    Just like @EatSleepTacos said, it'll come down what your needs are!
    By replacing the stock rubber bushings and ball joints with Trophy Truck quality Delrin Bushings and Uniballs, our boxed UCA substantially increases the strength and handling characteristics of your suspension and increases down travel.
    SoJersey, 13txtaco, jeff b and 5 others like this.
  4. Dec 21, 2016 at 7:55 AM
    dziner
    Jonathan
    Good question, and I'm not sure the answer to be honest. My guess would be both. Let's say I'm trying to go with a lift between 2" and 3", from what I read I will need to replace the UCA for a 3" lift, hence the many options for UCA's. Extra down travel would be an added bonus? But at what cost?
  5. Dec 21, 2016 at 7:56 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    First decide which kind of UCA do you want; Uniball or ball joint? Here's a basic breakdown of each.
    Balljoint: This type of aftermarket UCA uses a sealed balljoint (OEM also uses a sealed balljoint) which is a balljoint which lives in a rubber boot and is sealed from the elements. This type of balljoint requires virtually no maintenance, is silent, and offers more articulation angle than the OEM balljoint. Here's a list of examples of each.
    Specialty Parts Company (Light Racing SPC)
    JBA Off Road
    Uniball: This type of aftermarket UCA uses a uniball in place of the OEM style balljoint. Uniball is typically stronger than aftermarket ball joints, but is exposed to the elements which can lead to more maintenance and noise.
    Total Chaos
    ICON
    Built Right
    Camburg
    Baja Kits
    All Pro
    Both styles offer more articulation than OEM and will get your alignment where it needs to be when lifted.
  6. Dec 21, 2016 at 7:58 AM
    dziner
    Jonathan
    Added BajaKits to the lineup.
    Dbmann80 and JT@Bajakits like this.
  7. Dec 21, 2016 at 7:58 AM
    JT@Bajakits
    JT
    This right here!!
  8. Dec 21, 2016 at 7:59 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Curious to see more opinions. Im leaning JBA at the moment.
    Sna and 1truckdriver like this.
  9. Dec 21, 2016 at 8:00 AM
    dziner
    Jonathan
    Thank you for explaining the differences pros/cons of these two options. The uniball/balljoint option is something that is not really explained on product pages.
    Taco*Sauce06 and Jpat14 like this.
  10. Dec 21, 2016 at 8:01 AM
    dziner
    Jonathan
    JBA?
  11. Dec 21, 2016 at 8:02 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    AR15xAR10 likes this.
  12. Dec 21, 2016 at 8:03 AM
    dziner
    Jonathan
    Added them to the list. So many options, and range of prices.
  13. Dec 21, 2016 at 8:10 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yeah man, I'm sure I'm going to bring on the shit storm by saying this, but really just pick your UCA style and you'll be good to go. Unless you have specific needs you can't go wrong really with any of the list above.
  14. Dec 21, 2016 at 8:18 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Most all of the offerings now days are all good choices.
    The main reason for the UCAs is to correct low caster issues that happen from lifting the front suspension. By either being adjustable or by design the new aftermarket UCAs will fix the low caster and bring the alignment numbers back into factory spec for optimal driving and handling.
    As a secondary feature most of them also allow for some additional droop in the suspension. Providing a little extra travel.
    And third, the majority of the offerings are also and upgrade in strength compared to the stock units.
  15. Dec 21, 2016 at 8:19 AM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
  16. Dec 21, 2016 at 10:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Personally if I needed UCAs, I'd go with SPC light racing UCAs. They allow for the most adjustability and they're the cheapest of all the options. I believe they're sub $500.
  17. Dec 21, 2016 at 12:44 PM
    dziner
    Jonathan
    I will definitely make note of that. The range seems to go from $5xx to well above $1,000. It's difficult for me to understand why there is such a huge price difference for UCA's that essentially perform the same job.
  18. Dec 21, 2016 at 1:41 PM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I generally agree, but those billet Icons are beautiful. One might say, a work of art. :)
  19. Dec 21, 2016 at 1:42 PM
    JT@Bajakits
    JT
    Quality of parts, look/design, brand name etc...
    Kind of like buying jeans...you can buy Kirkland Jeans and it'll get the job done but people will shell out the extra $$ for Volcom and Quiksilver jeans because they like the brand and it looks better.
    Haha!
    grayfrog, Longshoreman and Dbmann80 like this.
  20. Dec 21, 2016 at 3:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There's a difference between "cheap" and reasonably priced. Majority of people run these and have zero issues meaning they're of good quality.
