UCA decision?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco1004, Mar 17, 2021.
  1. Mar 17, 2021 at 6:18 AM
    Taco1004
    Taco1004 [OP] Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    First off, I know this has been discussed on here many of times. I’ve searched the forum and found lots of info on many brands and styles of UCA’s. I’m going to pull the trigger today on one of these two brands and want any friendly input on them and why.
    The two choices at hand are the Camburg X-Joint and the JBA’s. Yes, I want to run ball joint style UCA’s for two reasons... one, my truck is mostly a weekend warrior pavement princess 90% of the time, with minimal off roading for family camping trips. As well as occasional hauling of utility trailer or 18’ pontoon boat. Secondly, I live in Maryland. We have snow and salt a lot... so the less maintenance, the better.
    The truck is a 2020 DCSB TRD Sport 4wd. The suspension consists of the Eibach 2.0 front coilovers in the front set at 2.5” of lift. The rear is a basic Eibach Pro shocks and 1.5” blocks. No added weight other than a CBI push bar front bumper... maybe 70lbs at most.
    I am just looking for people that have run either the Camburg or JBA set ups and what they think... and any problems they may have encountered.
    -cheers!
  2. Mar 17, 2021 at 6:22 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Stock rims and tires?
  3. Mar 17, 2021 at 6:23 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Rims will be Enkei RPT1’s 18” and tires I have not decided on yet... nothing overly aggressive, thinking 275 all terrains
  4. Mar 17, 2021 at 6:23 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    JBA and with the money saved, an AAL!
    N5J_Taco and Thunder Fist like this.
  5. Mar 17, 2021 at 6:27 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    @dually
    any reason for the JBA’s? Other than the obvious $250 price difference?
  6. Mar 17, 2021 at 6:28 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This ^^^. With the JBAs larger tires require a specific wheel size and offset. And factory wheels you can only run up to a certain size tire. I have JBAs and have had zero issues.
  7. Mar 17, 2021 at 6:31 AM
    Sig Taco
    2021 Taco DCSB
    Make sure you have the right offset and backspace so the UCA clears your tires size.
  8. Mar 17, 2021 at 6:31 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    1. Stout as hell
    2. Greaseable BJ's and bolt bushings
    3. Moog BJ's made for a Chevy Silverado that you can replace and get from any parts store if need be
    4. Built in 3 degrees positive Caster
    5. BJ's bolted in and not needed to be pressed out to change
    6. Lifetime structural warranty
    Big tall dave and Lt. Dangle like this.
  9. Mar 17, 2021 at 6:31 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Camburg uses a proprietary ball joint while JBA uses a traditional moog that can be picked up pretty cheap at local auto parts store and are replaced easily.
    Skydvrr and Lt. Dangle like this.
  10. Mar 17, 2021 at 6:31 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    The Enkei wheels are 18x9 with 0 offset
  11. Mar 17, 2021 at 6:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. Mar 17, 2021 at 6:34 AM
    gotoman1969
  13. Mar 17, 2021 at 6:34 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    ...oh, I have a set of SpiderTrax spacers (front only) as well. Should push the wheel/tire away a bit to help with any possible clearance issues.
  14. Mar 17, 2021 at 6:35 AM
    dually
    dually Low and slow
    The sealed ball joint, grease points at the arm bushings and positive built in caster. Essentially the same thing you're getting with the Camburg, but at a cheaper price. They're the same tubing wall thickness (assuming same ksi material). I would say the Cerakote treatment on the JBA ball joint is definitely a 'cool' addition and should lead to less risk of corrosion.
  15. Mar 17, 2021 at 6:37 AM
    JoeCOVA
    Joe
    Colorado Springs
  16. Mar 17, 2021 at 6:37 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well I was using the JBA supplied ball joints, so it's a JBA issue.
  17. Mar 17, 2021 at 6:38 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    There is also this page for JBA with more specs. https://support.jbaoffroad.com/faq/what_wheel_n_tire_combo_works_with_jba-7.0.hc.ez
    That’s all I have to offer, I’m running SPC uppers.
  18. Mar 17, 2021 at 6:39 AM
    Sig Taco
    2021 Taco DCSB
    Too big of a spacer can cause more rubbing issues.
  19. Mar 17, 2021 at 6:43 AM
    JoeCOVA
    Joe
    Colorado Springs
    I think they use Moog?
  20. Mar 17, 2021 at 6:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They don't, not sure who they use. I only know this because this third set I replaced with moog since I only need these arms to last a few more months. The moog fit, but were definitely different than whatever they have.
