UCA for drop bracket lifts?
Discussion in 'Suspension' started by toyotahenry, Apr 19, 2022.
  1. Apr 19, 2022 at 7:10 PM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    Asking for a friend.. but does one need aftermarket upper control arms if they install a drop bracket based lift kit?
  2. Apr 19, 2022 at 7:13 PM
    Bishop84
    Bishop84 Well-Known Member
    No, the geometry is actually pretty good with DB lifts. Sometimes the bigger coil can hit the ball joint, but its very rare.
    If you look at a DB lifted truck the arms are fairly level, and if you look at a 3" lifted tacoma the arms are angled heavily down, same with tie rods.
    Typically the biggest pain is you need 17" rims or bigger due to the new knuckle.
  3. Apr 19, 2022 at 7:14 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    JBA does make a stock replacement UCA for this situation
