UCA grease boots are leaking. How do I fix?
Discussion in 'Suspension' started by A7XT, Sep 27, 2012.
  1. Sep 27, 2012 at 11:35 PM
    A7XT
    A7XT [OP] Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    Hey everyone,
    I was checking out the front suspension today and noticed that the rubber grease boots on the stock UCA uniball are leaking grease. The truck has a 2.5 lift with billy 5100's. Do I have to get new boots entirely or is there a way to refill the grease in there?
    Thanks
  2. Sep 30, 2012 at 10:44 PM
    A7XT
    Kyle
    WYOMING
    bump...has anyone dealt with this problem before?
  3. Sep 30, 2012 at 10:49 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Just make sure they dont run out and they Will be fine
  4. Sep 30, 2012 at 10:54 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'd just wait until they develop play and then replace the whole thing, not really a way to replace only the boots.
    You can use a needle adapter to pump in fresh grease though, if you do that just wait until you lose a bunch.
  5. Oct 1, 2012 at 11:39 PM
    A7XT
    Kyle
    WYOMING
    Ok thanks a lot! Know what type of grease I need?
  6. Oct 1, 2012 at 11:42 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I should say if you can see just a tiny hole you could clean the outside with some brake cleen and then hit the hole with some RTV.
    If you elect to use a needle adapter I'd use any grease you'd use in your u-joints. It's not so much as what you use but that they stay cleanly lubed. Any contamination will quickly create wear and thusly slop as would running them dry.
