UCA grinding noise, happens intermittently
Discussion in '1st Gen. Tacomas (1995-2004)' started by WinSlow939, Sep 26, 2016.
  1. Sep 26, 2016 at 6:30 AM
    WinSlow939
    WinSlow939 [OP] Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    Yo 1st Gen peeps,
    My neighbor came over cause they see me working on my rig quite often :D
    She has a 2001 DC 3.4L with like 240K, said that she took her truck to Toyota because there was a weird noise that the tech's found was the Drivers UCA. they told her they re-torqued and it should be good to go, also told her for a truck of that mileage she should expect weird noises:p noise came back a couple days later..
    I looked at the UCA, everything looked ok as far as bushings not rotting out or a ton of rust, also looked like the bolts hadn't been touched at all, fuckin tech assholes
    What surprised me, and I guess this is my question... was that the UCA seem to be pushed way up towards the wheel well o_O I asked her how many miles on the coils/shocks and she said she bought the truck new and never though they'd been replaced:eek:
    So, I'm thinking that the shocks/coils are so fucked that its causing the front end to droop too much, causing the UCA to be binding somehow, thus the noise
    Am I way off here?
  2. Sep 26, 2016 at 6:38 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    How much would you guesstimate the UCA is pushed up from parallel? Or from flat?
  3. Sep 26, 2016 at 6:43 AM
    WinSlow939
    Nate
    The Rock, Mass
    This ^^... that was the only thing that really caught my eye , it looked like quite a bit, hard to say in real measurements though. I guess the best thing to do is snap a pic, i'll do that after work
  4. Sep 26, 2016 at 7:02 AM
    cruiserguy
    Elijah
    SEKS
    Yeah, if it's that much, unless your used to seeing them angled above parallel if you have a lift, then must be some tired coils. If she doesn't care much about the ride or anything, I believe some aftermarket company makes a pre-assembled strut for them. Might be an easy way to make a buck for ya.
