UCA Help please!
Discussion in 'Technical Chat' started by 85yote09taco, Sep 6, 2010.
  1. Sep 6, 2010 at 3:05 PM
    85yote09taco
    85yote09taco [OP] Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    I installed my Built Right UCAs the other day and noticed that the red gussets that come with the kit look like they are blown out. So I figured that when I added the majority of the grease after I tightened everything down it pushed them out. So I loosened the main bolt up top and tried to see if I could get them to go back down but with no success here I am writing on TW. Do I need new gussets? Anyone else have this problem? I guess I can try to post pics later
  2. Sep 6, 2010 at 3:18 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Post some pics
  3. Sep 6, 2010 at 3:21 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Pics pics pics:cool:
  4. Sep 6, 2010 at 3:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Those are bushings. You pumped way too much into them, and now they are bulging. You need to loosen the UCA bolt, and remove the grease zreks to allow the exess grease to bleed out.
  5. Sep 11, 2010 at 9:08 PM
    85yote09taco
    Eric
    York, PA
    Tacoma TRD OR
    someone else told me a similar story, thankyou for your input
