UCA Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mventure._, Jan 23, 2016.
  1. Jan 23, 2016 at 12:03 PM
    mventure._
    mventure._ [OP] Active Member
    Mark
    Phoenix, AZ
    '15 Silver V6 Tacoma TRD Sport 4x4
    3" Lift with Fox 2.5 RR extended coilovers, Total Chaos UCAs, OME Dakar leaf packs, Archive Garage shackle flip kit, Archive Garage U-Bolt flip kit, Wheelers Superbumps, Wheelers extended brake lines, Bilstein B110 rear shocks, 1.25" wheel spacers, 295/70r17 Cooper STT Pros, SDHQ 3-way spare tire carrier in bed
    Might be a stupid question but I'm installing my total chaos upper control arms and wondering if when the uca moves up and down is the through bolt suppose to move with it or just the bushings?
  2. Jan 23, 2016 at 12:04 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The bolt does not move once torqued.
  3. Jan 23, 2016 at 12:07 PM
    mventure._
    Mark
    Phoenix, AZ
    Hmmm.. When I have it tightened and even when I loosen it a little the whole bolt is moving with the arms. Not sure what to do.
  4. Jan 23, 2016 at 12:13 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I've only ever worked with rubber arm bushings and with those, the bolt does not move when the suspension travels.
    So I'm advising you based on a theoretical situation in my head, lol.
    Bolt, once torqued, applies tension to the bushing sleeves and the frame. If torqued right, it should not move in my opinion.
