UCA install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Aug 29, 2016.
  1. Aug 29, 2016 at 8:55 AM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I'm having the shop I work at do the install of my LR UCAs, top plate spacers, and extended studs today. I'd do it myself but I wrapped my leg around a mailbox and snapped my femur in three places :annoyed: . Anyway, is there anything I should tell the guy or advice you have to make things easier? Should the ball joints be greased too or just the bushings? Thanks guys.
  2. Aug 29, 2016 at 8:59 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    There should be a pretty self-explanatory instruction sheet that comes with the LR UCA's. I believe they now come with greasable ball joints. I would assume those need to be greased after install. Just make sure he has the installation guide that came with them.
  3. Aug 29, 2016 at 1:37 PM
    03f5sp
    Bill
    Wisconsin
    Anything else? I thought I read something about using a hammer to bash something out of the way so the UCA bolts come out easier.
  4. Aug 29, 2016 at 1:42 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    There's a piece of sheetmetal that needs to be slightly bent - hammer would do it I guess, but I just used pliers. It doesn't need to move too far.
    Also there's a wire harness under the battery tray that should be unclipped and moved out of the way - otherwise it may break when you start pushing the bolt out.
    Also I would insist that they not try and cut corners by re-installing the bolt backwards - make them put it back in the way it came out.
    CementTRDOffRoad and medic2230 like this.
  5. Aug 29, 2016 at 1:49 PM
    03f5sp
    Bill
    Wisconsin
    What should my caster be? I have them set at +4°. It's being worked on right now..
  6. Aug 29, 2016 at 1:53 PM
    Harry
    Santa Fe NM
    The consensus around here seems to be at least 2.5 degrees, maybe up to 3 if you can get there. 4 is too much IMO- that would be in the hard steering effort and "caster wobble" zone I think.
  7. Aug 29, 2016 at 2:05 PM
    03f5sp
    Bill
    Wisconsin
    I've read that with 285s you need at least +2.75° caster to avoid rubbing while turning full lock. I'm running 285/70r 17 currently.
    What is the caster wobble?
    From what I've read more caster helps keep the wheels straight over bumps and rough roads. We have terrible roads here in WI. I don't mind slightly heavier steering if it means the truck will track more straight.
  8. Aug 29, 2016 at 2:26 PM
    03f5sp
    Bill
    Wisconsin
    I set them at +3° caster. I can change it later on if need be.
  9. Aug 29, 2016 at 3:18 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Holy crap. 4+? Yeah I've always heard 2.5 - 3 (max).
    Make sure they know to use the grease provided with the LR UCA's. As I understand they like a specific grease being used... otherwise they can squeak. Mine did and I had to get my installer to re-grease them.
  10. Aug 29, 2016 at 3:48 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If you dont mind me asking, how much did the LR UCAs go for?
  11. Aug 29, 2016 at 3:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    Make sure they know the long bolt torque is 83 lbs and the big nut that holds the ball joint in is 150 lbs.
  12. Aug 29, 2016 at 3:52 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    How did you wrap your leg around the mailbox.... and how fast?? :eek:
  13. Aug 29, 2016 at 3:55 PM
    soupisg00df00d
    soupisg00df00d Well-Known Member
    Mark
    Eastern North Carolina
    2012 White Tacoma V6 4x4 6 speed manual
    Bilstein 5100s 884s Toytec prog. AAL SPC UCAs ProComp 5001s 16x8 Copper discoverer RTX 265/75r16 Black rear bumper Color matched grill surround
    Make sure they put the bolts in from front to back. They may be lazy and not want to bend the metal piece out of the way. If that's the case they might install them back to front which is a safety hazard IMO.
    medic2230 likes this.
  14. Aug 29, 2016 at 3:58 PM
    medic2230
    Murph
    Bama! Roll Tide
    I agree. My nut came loose and if that but had fallen off then the bolt could slide out of it was in opposite of stock. I heard a noise and checked it and found it.
  15. Aug 29, 2016 at 5:21 PM
    03f5sp
    Bill
    Wisconsin
    I think $485.
    I'm told I wrapped it around a mailbox. I was on a scooter and don't remember the accident.
    He put them in backwards. Could I just take the nut off, use Loctite and torque it to 83 ft lbs? Otherwise I'd have to take off the UCA off to get the bolt back in and then get it realigned.
  16. Aug 29, 2016 at 5:24 PM
    medic2230
    Murph
    Bama! Roll Tide
    Locktite sounds like a winner to me. I just keep an eye on them and check torque every so often. Good idea to get in there anyway so you spot anything that may be going on you just don't know about yet.
  17. Aug 29, 2016 at 5:25 PM
    03f5sp
    Bill
    Wisconsin
  18. Aug 29, 2016 at 5:26 PM
    medic2230
    Murph
    Bama! Roll Tide
    Ouch.
    That left a mark.
  19. Aug 29, 2016 at 5:26 PM
    03f5sp
    Bill
    Wisconsin
  20. Aug 29, 2016 at 5:29 PM
    03f5sp
    Bill
    Wisconsin
    The third break up near my hip socket.
