UCA install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doris_the_taco, Aug 5, 2022.
  1. Aug 5, 2022 at 1:51 PM
    doris_the_taco
    doris_the_taco [OP] Well-Known Member
    Ian
    2008 Tacoma TRD Off-Road
    Looking for someone in Denver or Colorado Springs area to install a set of UCAs for my 08 tacoma 2.5 inch lift with bilstein 1500s and eibach coils
  2. Aug 5, 2022 at 2:41 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    UCA’s are pretty straightforward not a hard job at all, you will need duckbill vice grips to make life easier to bend back pinch welds slightly
  3. Aug 5, 2022 at 2:58 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    It's a pretty easy job. The only difficult part I found was getting the long bolt that attaches the arm to the frame out. It's blocked by the body/wheel well sheet metal, so you might need to bust out some pliers like @Greeves77 mentioned.
  4. Aug 5, 2022 at 3:15 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
  5. Aug 5, 2022 at 3:25 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    @YamaDirtrider
    burrito782 likes this.
  6. Aug 5, 2022 at 3:28 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It's not that easy. Sometimes the long bolt can be a real PITA to remove. If you aren't mechanically inclined, it's not an easy job.
  7. Aug 5, 2022 at 3:30 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Uca are easy as hell I just replaced mine only took me an hour for both
  8. Aug 7, 2022 at 2:50 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    this
