UCA/lift questions
Discussion in 'Suspension' started by ryantaco, Jun 16, 2013.
  1. Jun 16, 2013 at 12:47 AM
    ryantaco
    ryantaco [OP] Well-Known Member
    SoCal
    06 DC Long Bed TRD Sport
    If i plan on leveling my truck with 5100's all around or just in the front am i going to need new UCA's or just alignment?
  2. Jun 16, 2013 at 12:52 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    you should be fine with just the 5100's and an alignment
  3. Jun 16, 2013 at 1:21 AM
    Ninjayota
    Ninjayota Well-Known Member
    South Texas
    2012 regular cab base 4x4
    Mb 352 wheels, 265/75/16 duratracs
    So how high can you go without having to mess with the uca?
  4. Jun 16, 2013 at 1:31 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    general rule is 2.5"
    I was at 3.5" before I swapped my UCA (in-process now), didn't have any major problems besides blown CV boots.
    but that's a different story
    but every truck is different. Some people will be fine, some will get vibes
  5. Jun 16, 2013 at 3:45 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Wouldn't the year of the vehicle make a difference? I am under the impression your info is in regards to an early Tacoma while the OP is asking about a late style Tacoma.
    PK
  6. Jun 16, 2013 at 5:36 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    About 2.5" is the max and that is pushing it from everything you'll read on here.
  7. Jun 16, 2013 at 3:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    not really. our vehicles all have the same suspensions; sans differently placed bolt holes and model specific hardware
    lifting affects both ifs systems the same
  8. Jun 16, 2013 at 3:15 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    I am at about 3 or a bit less and no vibes just recently started getting neg camber wear on my tires. But also in the process of UCAs and spindles to lower my preload
  9. Jun 29, 2013 at 10:04 PM
    ryantaco
    SoCal
    Whats the biggest wheel size i could run with that kind of lift?
