Uca moog bushing part#
Discussion in '1st Gen. Tacomas (1995-2004)' started by lshouse35, Mar 17, 2015.
  1. Mar 17, 2015 at 10:16 AM
    lshouse35
    lshouse35 [OP] Active Member
    Lawrence
    Havelock nc
    04 tacoma 2.7
  2. Mar 18, 2015 at 10:52 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  3. Mar 18, 2015 at 1:00 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    I have looked at the poly bushings and research it members on this forum said they are squeaky and are not as good of quality as rubber oem the bushings from toyota are crazy high $ that's why I'm wanting to go with moog but i deff want the right ones for the upper
  4. Mar 18, 2015 at 3:34 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    if you put the grease/lube on them they will be fine. I did my sway bar/steering rack bushings last summer and so far haven't heard a peep (put a "little" on the outside, bushing just helps dampen and center the part)
    I bought the whole kit as it was cheaper in the long run, already know I need new leafs and shocks soon so figured I'd swap them out when I do it.
    www.rockauto.com also only lists one for the upper (same part #) and they are $12+ shipping
    2002 TOYOTA TACOMA 2.7L L4 : Suspension : Control Arm Bushing Price
    MOOG Part # K200125
    {#4863235070} Sold individually
    Front Upper; RWD; DLX Model
    Part Image
    $12.10
    BECK/ARNLEY Part # 1017694
    Front Lower; 4WD
    Part Image
    $15.67
    MOOG Part # K200119
    {#4806135040} Incl. front and rear bushings One of our most popular parts
    Front Lower
    Part Image
    $16.11
    ACDELCO Part # 45G9215
    {#89036903} Professional
    Front Lower
    Part Image
    $19.10
    RAYBESTOS Part # 5651215
    Professional Grade; 1 Bushing - Silentbloc w/Ferrules
    Front Lower (Only 1 Remaining)
    Part Image
    $19.11
    http://www.autopartswarehouse.com/sku/Beck_Arnley/Control_Arm_Bushing/101-4312.html
    Beck/Arnley brand here
  5. Mar 19, 2015 at 4:04 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    That's good wood frizzman it's decision time for the price I'm leaning on poly bushings if I grease the heck out of them when i press them in I shouldn't have any noise issues ?
