UCA Necessary?
Discussion in '1st Gen. Tacomas (1995-2004)' started by travis9287, Feb 27, 2013.
  1. Feb 27, 2013 at 9:57 PM
    travis9287
    travis9287 [OP] Well-Known Member
    Travis
    Tuscaloosa,AL
    2003 Tacoma, 2006 GX470, 2000 Jeep TJ, 1985 C10
    a lot lol
    Okay guys, i have a small issue. I am running the OME setup with 881's and Dakars. Everything is wonderful with the lift, i love it. But I havent even had tires on 9 months and im already down to a 3/32 and even a 2/32 on the driver rear. Im running the Hankook RT03's. I'm assuming it was a bad alignment. I've never had a "real" alignment due to having issues finding anyone that would mess with it. I've heard mixed opinons on if UCA's are necessary. The only thing im really concerned about ATM is tire wear. I want to eventually get UCA's but are they necessary before i get the new tires?
  2. Feb 27, 2013 at 10:49 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Go get an alignment. I can tell you need one by your sig pic and build thread
  3. Feb 27, 2013 at 11:25 PM
    travis9287
    Travis
    Tuscaloosa,AL
    a lot lol
    Thats the problem, i cant find anyone that will actually touch it. They all keep saying UCA, UCA. but i know there are people on here without UCA's that have gotten alignments and gotten it pretty close within spec.
  4. Feb 27, 2013 at 11:28 PM
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    A good shop shoud be aible to do the aligment without the UCA. Try your Toyota dealer.
  5. Feb 27, 2013 at 11:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    X2
    Shouldn't need it. Your not even over 2.5" lift. Got mine near perfect with 3"+
    You need an alignment. The UCAs would help that much. Unless you want to get them for future mid travel.
  6. Feb 27, 2013 at 11:38 PM
    travis9287
    Travis
    Tuscaloosa,AL
    a lot lol
    As long as i can get it so it dosent wear tires ill be fine for now. i would like to get them in the future. but i have other important things right now.
  7. Feb 28, 2013 at 6:37 AM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    OME and UCAs I've seen very mixed responses. Shouldn't be necessary. I mean, the UCA wouldn't hurt but it shouldn't be necessary w OME. Go find a shop that'll do an alignment.
  8. Feb 28, 2013 at 8:16 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    With my ome 881 coils and 1/4" top plate spacer I am almost at 3" of lift. To get the amount of caster that I was looking for I had to go with light racing uca's. Even though I may have not needed them I decided to go with them to get a perfect alignment. I don't see how anybody with over 2" of lift is getting close to 3 degrees of caster on their alignment without an aftermarket uca.
  9. Feb 28, 2013 at 12:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The main reason for upgrading the UCAs is to gain back the Caster adjustment lost when you lifted your truck. However, a low caster setting will not impact on tire wear.
    The Camber and Toe settings in your alignment are thrown off when you add lift and will cause excessive tire wear . The stock UCAs do not prevent your truck from being able to attain correct Toe and Camber even after a lift is put on.
    Find a reputable alignment shop, they will tell if your Toe and Camber cannot be set correctly so you wont wear out your tires. They will be able to identify the exact cause, like worn out bushings or tie-rods. The reason will not be because you do not have an aftermarket UCA.
  10. Oct 18, 2014 at 10:43 PM
    truxartis
    truxartis Member
    N. Dallas
    99 PreRunner
    OME N91s 881 coils, OME N85, AAL
    I'm considering adding UCA's, due to the same issue. After an OME 881/N91S upgrade, my tires (Dueler 31/10.5R15) are showing pretty good amount of cupping / scalloping along the outer half. I've taken it to several shops for an alignment, and it hasn't helped (the the cupping). It drives fine and straight, with no wandering. Now, I feel even more confused after finding this thread....
  11. Oct 19, 2014 at 2:33 PM
    JonEvans56
    JonEvans56 Well-Known Member
    Andrew
    Dead Truck
    Rust, dents, cracking plastic, oxidized paint...
    A good shop should be able to get you in spec. UCAs would be for 3+" of lift. The OME kit gets you a bit under 3", more like 2-2.5". I wouldn't worry about UCAs unless you want to stay IFS for a long time or get more travel out of your IFS.
  12. Oct 19, 2014 at 4:54 PM
    truxartis
    truxartis Member
    N. Dallas
    99 PreRunner
    Thanks.
    Can anyone recommend a good shop in the DFW or Plano area?
