UCA pivot bolt question
Discussion in 'Suspension' started by RacerP, May 18, 2012.
  1. May 18, 2012 at 8:03 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I am trying to install some custom fabbed UCA's and the stock pivot bolt going thru the bushngs is not long enough.
    I know it's a 14mm, but, does anyone know if ones off a Tundra or Land Cruiser are any longer than the Tacoma ones? I did call the local dealer and they don't have any in stock to compare it to.
    The best I have been able to come up with is some threaded rod from Fastenal and use lock nuts on both ends?
    From the pictures I am assuming I don't have enough thread to be safe? Perhaps get rid of the flange nut and just go with a regular lock nut?
  2. May 18, 2012 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont use a fully threaded rod. It doesnt have the required shear strength. And Yes, You need more thread showing.
  3. May 18, 2012 at 8:25 AM
    RacerP
    Chicago
    2003 4x4
    What would be an alternative solution? As far as I can search no one carries a 14mm bolt that long? Unless a Tundra or Land Cruiser bolt is 14mm and slightly longer?
  4. May 18, 2012 at 8:43 AM
    RacerP
    Chicago
    2003 4x4
    And I just got off the phone with McMaster Carr and they have threaded rod in Grade 8. Isn't that the same as most suspension fasteners?
  5. May 18, 2012 at 8:47 AM
    medic2230
    Murph
    Bama! Roll Tide
  6. May 18, 2012 at 8:51 AM
    RacerP
    Chicago
    2003 4x4
  7. May 18, 2012 at 8:53 AM
    medic2230
    Murph
    Bama! Roll Tide
    Sorry, didn't notice the grade 5 at the bottom. I looked and saw the 8.8 above it.
  8. May 18, 2012 at 8:53 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Loads on the UCA aren't that high, actually. Grade 5 will work, but you can't torque it to OEM specs. The Fastenal bolt has a plain finish, though, which will cause the bolt to rust out within one winter in Chicago.
    Do the outboard bushing flanges need to be that thick?
    Since the bolt is in shear, another solution is to use a jam nut. Only 7mm thick:
    http://www.fastenal.com/web/search/...2900|~ ~|sattr02:^Steel$|~ ~|sattr04:^Zinc$|~
  9. May 18, 2012 at 12:28 PM
    RacerP
    Chicago
    2003 4x4
    I was actually thinking about the jam nut. But, never thought about shaving off some of the flange on the bushing, there is plenty of meat on it.
  10. May 18, 2012 at 12:30 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    why dont you just order the oem bolt?
  11. May 18, 2012 at 12:39 PM
    RacerP
    Chicago
    2003 4x4
    That's what I have in there and it's not long enough. The way these were fabbed, the made the pivot housing extra wide.
  12. May 18, 2012 at 12:40 PM
    rondog
    Ronnie
    Escondido/San Diego
    oh, gotcha..that's weird. Are they TC UCA?
    edit: nvm I see you said custom. I would try these guys too http://www.ababaqa.com/
    You can call them and if they don't have a long enough bolt in stock they can order you one. I've bought many bolts from them
