UCA Question for a minimal lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ejewels, Nov 6, 2018.
  1. Nov 6, 2018 at 12:28 PM
    #41
    su.b.rat
    su.b.rat broken truck
    this is so damn true. my SPC's were originally installed incorrectly because i didn't use a truck shop to install them. the drama that lead to for me would bend your mind. 2 months of it with shit breaking everywhere. the SPC's are great, tough & adjustable, but you must do them correctly. i have lived & learned the very hard way. 4 shops, 8 alignments, and over $2500 in fees to diagnose this shit.
    and ironically the truck is coming out of the bay as i write this... all done now. sorry if I'm jacking the thread.
  2. Nov 6, 2018 at 12:48 PM
    #42
    ejewels
    ejewels [OP] Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    How can they be installed incorrectly? Sounds like the original shop should pay those bills.
  3. Nov 6, 2018 at 12:56 PM
    #43
    su.b.rat
    I'm not even getting into this story. it's horrible and complicated. I'll take the hit for poor planning. can't offload that blame. the SPC's are great and get me the caster numbers i like.
    2k4Taco likes this.
  4. Nov 6, 2018 at 12:57 PM
    #44
    ejewels
    CT
    I hear ya. I'm hoping the JBAs are more idiot proof for installation lol.
    su.b.rat likes this.
  5. Nov 6, 2018 at 3:01 PM
    #45
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    The difficulty installing SPCs comes from choosing the proper setting for the ball joint. This is simple if you have the instructions in front of you, but most shops throw away instructions
  6. Nov 6, 2018 at 3:01 PM
    #46
    su.b.rat
    exactly what happened, in fact.
  7. Nov 6, 2018 at 3:11 PM
    #47
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    At that height i would say don't even worry about it. Firestone did my alignment and they did whatever they do. I did not request anything special. Zero issues and handles great. It aligned just fine. I have stock upper control arms. If you do get an upper control arm i would say to still not worry about it because the alignment tech will get it in spec no problem. I had adjustable upper control arms on my 350z. Never had to provide any numbers.....the upper control arm allows the alignment tech the additional adjustment he needs to get it into spec.
    Honestly i would say to not spend the $$ on upper control arms if you are going 1.5 max. Spend the money you saved on the part and labor and purchase an OVtune.
  8. Nov 6, 2018 at 3:14 PM
    #48
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Another bonus of having adjustable UCAs like the SPC is that you can still get an alignment once your alignment cams seize a couple years down the road. Also I dont get how people have so much trouble getting the UCA bolt out... I have installed about 5 sets of SPC UCAs on 2nd and 3rd gen Tacomas without trouble... cutting the old ones out takes longer..
  9. Nov 6, 2018 at 3:17 PM
    #49
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    I would go with SPC uppers. Insanely adjustable, easily rebuildable. I've got my castner at +4.5 * with no rubbing. They wont have any negative effects even if you were running stock suspension. And you're right, buy once, cry once...
  10. Nov 6, 2018 at 3:19 PM
    #50
    su.b.rat
    i was running 5.2deg caster on the passenger side last chapter before i had these issues. all issues fixed now, but I'll be sticking with 4.5deg both sides with tomorrow's alignment.
    2k4Taco[QUOTED] likes this.
  11. Nov 6, 2018 at 3:43 PM
    #51
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    I went with camburg ball joints. Alignment was a breeze and they work like tajin with Mexican beer....magical.
    ejewels[OP] and 2k4Taco like this.
  12. Nov 6, 2018 at 3:48 PM
    #52
    2k4Taco
    Swanny
    Fleming Island, Fl
    Camburgs are great uppers, but, with the uniball exposed, it's more susceptible to debris and moisture bc it's open to the environment with can lead to corrosion and premature failure. Enclosed joints, i.e. SPC, JBA and Icons Delta joint (ball joint type) have much more longevity and SPC has much more adjustability.
  13. Nov 6, 2018 at 4:26 PM
    #53
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    My Camburgs are sealed with Moog ball joints.
  14. Nov 6, 2018 at 4:44 PM
    #54
    Tacohumper13
    Menifee
    Your right! That’s why I went with ball joint camburgs.;)
