UCA question
Discussion in 'Suspension' started by HolyReptar, Jul 30, 2012.
  1. Jul 30, 2012 at 9:58 AM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I have some TC UCA that I need to lube and was wondering what lube you guys are using for the bushings and the uniball?
  2. Jul 30, 2012 at 10:18 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    ImageUploadedByTapatalk1343668729.599049.jpg in the uniball and Mobil1 in the bushings.
  3. Jul 30, 2012 at 10:20 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Tri-Flow® Superior Dry Lubricant: $5.89
    Tri-Flow® Superior Dry Lubricant is an elite formula created for dry and dusty conditions. The 2oz drip bottle applicator allows for deep penetration in hard to reach moving parts. Featuring paraffin wax and high-grade petroleum oil to allow the lube to go on wet, but then set up in a dry, 'wax-like' film so it will not attract or absorb grit and grime. Perfect for dry, dirty, dusty conditions, while still providing adequate wet weather performance. Holds up to extreme pressures and resists water wash-off. Provides incredible efficiency without attracting an excessive amount of contaminants. Great for Uni-Ball bearings.
  4. Jul 30, 2012 at 10:21 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I just spit on it
  5. Jul 30, 2012 at 10:22 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    but really, the tri flow is good. you can pick it up at your local bike shop,
  6. Jul 30, 2012 at 10:23 AM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I have the camburg uniball UCA's. How often do they need to be lubed?
  7. Jul 30, 2012 at 10:27 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    alright sweet, might be a dumb question but how do you get mobile 1 into the bushings lol... and trying to find the best lube for the bushings
  8. Jul 30, 2012 at 10:52 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Personally if I had uniballs I'd be using dry moly spray lube. Bushings I'd probably go with valvoline full syn grease, I'd have to check and see if those bushings would be compatible though.
  9. Jul 30, 2012 at 10:53 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    +1
    Lowes/Home Depot has it
  10. Jul 30, 2012 at 10:56 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    LOL looks a little dirty, like oil and dust.
  11. Jul 30, 2012 at 11:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If that looks dirty-You shouldn't look at my truck....
    Mobil1 in the grease tube works great with my grease gun. That is what the zero fittings are for...or if thy are off the truck you can take them apart to refill them if you want...
  12. Jul 30, 2012 at 11:03 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    oh sweet any specific type of Mobil1 grease tube I remember seeing different types at napa
  13. Jul 30, 2012 at 11:09 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I thought you were gonna say girl, damn. :poking::bananadead:
    Check out the dry moly though.
  14. Jul 30, 2012 at 11:13 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    thanks for the replys everyone appreciate it
  15. Jul 30, 2012 at 11:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The normal Mobil1 synth grease should do. Or any other reputable brand you like.
    And Max-I think the lube you use and the stuff I use are really pretty similar. That Teflon type doesn't attract/hold dirt like a grease or WD40 type lube. And I've had great luck with that same lube on motorcycle chains, appliances, and yard tools for years...
