UCA Question
Discussion in 'Wheels & Tires' started by kc10driver, Apr 4, 2010.
  1. Apr 4, 2010 at 9:39 PM
    kc10driver
    kc10driver [OP] Member
    quick Question,
    I have an 09 DC Sport.
    If I keep my stock wheels and upgrade my UCA's to TC UCA's, how wide of a tire might I be able to go with. I think, as of right now (completely stock) I can only get 265/70R17 to fit.
    Would these new UCA's allow me to go wider (if so, what size) and have no rubbing issues? Anyone out there done this yet?
    Thanks!
  2. Apr 4, 2010 at 10:24 PM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    With the stock rims??
  3. Apr 4, 2010 at 11:42 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Curious: do aftermarket UCA's have an undesired effect on caster with stock suspension?
    OP, Spidertraxx hub-centric wheel spacers will also give you more space for wider tires for about $200 front and back, easy install.
  4. Apr 4, 2010 at 11:56 PM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    Aftermarket UCA's have a positive 2 degree caster built into them. They are designed to correct your alignment after a lift. I do not know if you have enough adjustment to get the alignment correct when you do not have a lift. On the tacoma, there is one adjustment that changes caster and camber. You have to find a happy medium with it. If you went with Light Racing UCA's, they have thier own camber adjustment built into them (I am not sure if the others do or not). I would think that you would be able to get away with it, but I am not sure I would even worry about it. If you are only trying to go a little bigger in the tire size, I would just get a set of spidertrax spacers.
