UCA Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UofA Taco, Apr 18, 2010.
  1. Apr 18, 2010 at 11:48 AM
    UofA Taco
    UofA Taco [OP] Well-Known Member
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    K&N filter 3" Toytec lift
    I'm going to set my 5100s @ 2.5 in the front, i have the 1/4 top platre spacer but I'm not quite sure if I will put it on also or not yet. I see on here were everyonr running 2.5 with spacer has new UCAs. Do you need new UCAs with every 3"+ front lifts or is it just a Billy thing? They help with alignement I know but is there any other purpose? My old tacoma had 3" spacer in the front and i never got new UCAs and it aligned back up just fine.
  2. Apr 18, 2010 at 11:52 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Helps get your alignment back to spec. 3" is a good rule of thumb.
  3. Apr 18, 2010 at 11:54 AM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    you dont have to but I would if you have the budget...I didnt and now every time I drive down the freeway I wish I would have. But once again you dont have to
  4. Apr 18, 2010 at 1:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would say, anything over 2" may need different UCA's. ;)
  5. Apr 18, 2010 at 2:15 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    you can get your alignment to spec with the 2.5" BILSTEINS
  6. Apr 18, 2010 at 2:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "In spec" at the oposite ends of the range maybe. But 0* Toe, Camber, and 2.4* + Caster, Nope.
