UCA removal...Is there a better way?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoytoda, Nov 29, 2009.
  1. Nov 29, 2009 at 7:07 PM
    Yoytoda
    Yoytoda [OP] The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    I was looking at what it would take to replace the UCA. The only way i can see to do it is to remove the inner fender which would be a PITA. Maybe bend the inner fender out of the way or maybe drill a hole but that would bother me. What have you guys done?
  2. Nov 29, 2009 at 7:15 PM
    ruppmeister
    ruppmeister Well-Known Member
    Colorado
    09 TRD Offroad
    Moto Metal Skull 17x9, BFG KM2's 285/70R17, Toytec ULK, LR UCA
    IIRC the shop that did mine charged me for two bolts when they cut out the original ones. They told me that they put the bolts in backwards when they put in the new UCA. Just a thought.
  3. Nov 29, 2009 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Correct. Or, as you can see in the write up Silver06TRD did, you can just bend a little bit of the fender, and tap out the bolts. When you re install, you can insert them from the rear.
  4. Nov 29, 2009 at 7:17 PM
    Yoytoda
    Roland
    completely stock
    How would you get the new ones in?
    Edit: read the other posts. i noticed there was room behind the ucas, just put the new ones in backwards. never thought about cutting the old bolts out Thanks
  5. Nov 29, 2009 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From the rear.
  6. Nov 29, 2009 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Nov 29, 2009 at 7:41 PM
    Yoytoda
    Roland
    completely stock
  8. Nov 29, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help, you guys! :)
  9. Nov 29, 2009 at 8:16 PM
    Yoytoda
    Roland
    completely stock
    I have a pretty good knowledge of the way things work from years of taking crap apart and putting it back together and fixing crap i break on myself. But there is always something else that can be learned...:bowdown:
  10. Nov 29, 2009 at 8:18 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    The passenger side was hardest for me. I bent the fender all out of whack and finally took a pair of tin snips to some of it. The drivers side was a piece of cake after that.
  11. Nov 29, 2009 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Best way is to bend just a little bit, enough for the head to clear, then tap it out with a couple of 3/8" socket extensions. Its pretty easy that way.
  12. Nov 30, 2009 at 6:39 AM
    novakills
    novakills Well-Known Member
    Scott
    Tampa FL
    2010 Prerunner TRD Sport
    TRD CAI, debadged, TRD exhaust, bed d-ring mod, rubber bed mat, 6000K Bi-xenon headlights, 3000K HID foglights, Redline Tuning QuickLIFT PLUS Hood Struts, 2" Toytec AAL w/Bilstein 5100s, 1" aluminum tapered leaf spring spacer, Eibach 1.6" lift coils on Bilstein 5100s set at .85 with Light Racing UCAs, 10% tinted windows, 285/70/17 Toyo Open Country A/T, Pioneer MVH-X560BT,TRD Supercharger, Grillcraft Black MX upper and lower grill, RAAMmat Sound Deadening, Hybrid Audio Technologies Imagine Series I61-2 in rear doors, Hybrid Audio Technolgies Legatia L6 and L1V2 in front doors running through Hybrid Audio Legatia L2X crossovers, JL Audio 13TW5 in a bedlined Mr. Marv enclosure, Zed Audio Leviathan Amp on a bedlined Mr. Marv amp rack, DTLT Exhaust Headers w/O2 simulators, full LED lighting interior and exterior, OEM roof racks
    I just replaced my UCAs 3 days ago and it wasn't too difficult to massage the sheet metal out of the way to get the bolts out. However, I put the driver's side back in the way it came out because the fuel lines were in the way of going in from the rear. The passenger side was very easy after doing the driver's side.
  13. Nov 30, 2009 at 8:38 AM
    sonjay
    sonjay Well-Known Member
    Just bend it a little bit and tap it out, I found it easier to go back in from the front because of brake lines or fuel lines?
  14. Nov 30, 2009 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On the driver side, those are the fuel lines. Seems to very truck to truck, as some I have been able to pop right back the way they came out, while others I had to insert the bolts from the rear....
  15. Nov 30, 2009 at 9:28 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Best bet is too just bend the fender a little bit to get the bolt out. Even if you cut off the bolt and buy another one and if you put the bolt back in the proper way (way they are from the factory), you will have to bend the fender a bit to get it back on. When I changed my ucas, I was worried at first too, but it just sounds worse then it really is. The fender bends really easy and you only have to bend it a little bit. This is the best way in my opinion.
  16. Nov 30, 2009 at 3:08 PM
    Yoytoda
    Roland
    completely stock
    Im really anal about scratching any paint on anything being from northern ny (salt). If i cut the bolt slide it out of the rear and slide the new one in backwards, i wont risk breaking the paintsurface from gripping with channel locks or over stress the paint causing it to chip.
    Is there any downside to installing the bolt backwards and use lock tight?? deosnt seem like it matters at all. if i was over paranoid and thought locktight would fail, i could drill a small hole through the nut and bolt and cotter pin it.
  17. Nov 30, 2009 at 3:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont even use lock tight. Never had an issue on any I have installed.
  18. Nov 30, 2009 at 3:11 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I would help you if you need help. The easiest IMO is the way Chris does it. Has worked great on the 4 sets I have done.
  19. Nov 30, 2009 at 3:11 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    x2
  20. Dec 1, 2009 at 11:28 AM
    sonjay
    You could easily grab a can of undercoat or some rust inhibiting paint and give it a spray after you have bent it back, you can't see where you have to bend the sheet metal unless you get right in there and take off the rubber mud guard thing. I don't really think lock-tight would be needed on this item. There was none from the factory...
