UCA Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mavrick, Apr 6, 2018.
  1. Apr 6, 2018 at 6:19 AM
    Mavrick
    Mavrick [OP] Well-Known Member
    2015 DCSBOR
    I've watched all the video's and read most of the threads on how to change out the UCA's but when looking at my taco it looks like there is no way that long bolt will slide out even after bending the fender. On the driver side the battery is there and on the passenger side there is a bunch of metal lines in the way. I suppose there is enough slop/wiggle room once it becomes loose to work the bolt around everything but just wanted to be sure. I can post pictures if needed but figure all tacos are the same. Mine is a 2015 if that matters.
    Before I rip everything apart I just want to make sure I'm not overlooking anything.
  2. Apr 6, 2018 at 6:28 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I ordered two spare UCA bolts/nuts before I began that endeavor. I wasn't interested in bending up/cutting my body so I cut the original bolts with a cutoff wheel and installed the new OEM bolts backwards which does not require any modification to the body.
    Crosis, blu92in99, Muddinfun and 2 others like this.
  3. Apr 6, 2018 at 6:28 AM
    badger
    badger Well-Known Member
    07 SR5
    Most people cut theirs and replace with new ones. The new ones can be inserted easily from the other direction. This is common practice, BUT, the reason the bolt comes in from the top originally is so that the bolt will not fall out if the nut works loose. The best way to do it is to come from the bottom and use some sort of locking scheme, like a second all metal locking nut, or possibly a castle nut with a cotter. It makes replacement and servicing so much easier.
    BassAckwards, AR15xAR10 and Tacotj like this.
  4. Apr 6, 2018 at 6:33 AM
    MMoreno16
    MMoreno16 Cupcake Forest Ranger
    Los Angeles
    2018 TRD OR DCSB
  5. Apr 6, 2018 at 6:35 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    The passenger side is harder than the driver side. It took me an extra set of hands and eyes to get everything moved out of the way as I worked the bolt out.
  6. Apr 6, 2018 at 6:38 AM
    Tacotj
    Tacotj Well-Known Member
    Ottawa ON
    2015 DCLB 4X4 Sport
    Fair bit of bending on the pass side (careful not to pinch any of the lines)
    I ended up removing my battery for clearance (just could not get past it)
    Doable once you get at it - good luck!
  7. Apr 6, 2018 at 6:46 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Does anyone have a link where I can order some new UCA bolts and nuts before I do mine as well? Should I go through the dealer?
  8. Apr 6, 2018 at 6:51 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
  9. Apr 6, 2018 at 6:52 AM
    doorsidedown
    doorsidedown Well-Known Member
    100% the way to go. I don’t worry one bit about them being in backwards.
    BassAckwards likes this.
  10. Apr 6, 2018 at 6:54 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I cut mine out with a sawzall. The pass side was easy, only took one cut. The drivers side was more difficult, i cut it twice.
    I am not worried about the bolt coming lose as i check them for tight before trips and always regrease the bushings every 3-5k. Just keep an eye on them and check them every once in a while and youll be good to go. I got my uca bolts from wheelers
    doorsidedown likes this.
  11. Apr 6, 2018 at 7:12 AM
    badger
    07 SR5
    Only use OEM bolts yes. Camelback Toyota here has a rep that gives us a discount. Contact Gunny
    There are thousands of trucks running around with backwards bolts. I've never heard of one coming loose. Shops even install them that way. Mine are that way, but I do plan to add lock nuts. I don't worry at all about a properly tightened, and loctited nut coming loose, but I would not go so far as to recommend it. Understand the risk and act accordingly. Adding an all metal lock nut is a cheap easy way to make it 100% safe.
  12. Apr 6, 2018 at 7:14 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    A set of large slip joint pliers did the job bending the thin metal nicely for me and I was able to reinstall the bolts the same way with some wiggling. No cutting required. One could remove the old ones by cutting as others have said and install new ones backwards as long as you have a good ny-lock or oval-lock nut on there it should be just fine. The amount of force or vibration needed to overcome a lock-nut is way more than these trucks would ever experience.
  13. Apr 6, 2018 at 11:20 AM
    Mavrick
    2015 DCSBOR
    Thanks everyone, cutting the bolt and replacing it is what I will be doing. I did not know that was an option.
  14. Apr 6, 2018 at 1:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It will take longer to cut out a perfectly good bolt than it does to simply massage the inner fender out of the way. I used vise-grips with a folded shop rag to gently bend the inner fender
  15. Apr 6, 2018 at 4:46 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Yep, just did this last weekend. Used some vise-grips and a rag to bend the inner fender a little bit. I popped some of the wire hold down clips that were in the area loose to to avoid damaging/getting hung up on the wire looms. I then used a cut off wheel on an angle grinder to cut the bolt heads off.
    On the driver side it was actually easier to re-install my new bolt the original direction instead of deal with the brake lines that were in the way. Passenger side got installed opposite.
    I found new bolts available via Amazon with prime shipping for $15 each. Reused the nuts I already had.
  16. Apr 22, 2018 at 11:11 AM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Does anyone have the part number for that bolt? I’m about to do the same thing.
  17. Apr 22, 2018 at 11:26 AM
    ToyoKühl
    ToyoKühl Well-Known Member
    Aaron
    UP Michigan
    2015 DCSB OR
    OME 887 with Nitrocharger Sports and full Dakar Pack SCS Coopers 255 85 rigid industries
    Just replaced the uni balls and bushings in my TC UCA yesterday and the passenger side bolt was the worst. I used said pliers in previous post to wiggle inch by inch. It was difficult but it got done. Also changed the oil and rotated ties in about 3.5 hours.
  18. Apr 22, 2018 at 12:00 PM
    JustDSM
    Justin
    Ogden, UT
    OEM Toyota PN#:
    90105A0095
    SnowB0und[QUOTED] likes this.
  19. Apr 22, 2018 at 12:37 PM
    SnowB0und
    4cyl 4x4
    JustDSM likes this.
  20. Apr 27, 2020 at 3:06 PM
    SAR Taco
    SAR Taco TRD-SAR
    Bryan
    PNW
    2009 Trd-Sport DCSB 6MT Super White
    2 in. spacer lift, rear facing halogen spot lights, leer 100xr canopy, FN Fx Pro wheels in Matte Bronze. Falken Wildpeak AT3W 275/70/17 LRC. Lots of LEDs. Rear ARB air locker.
    Just putting my 2 cents in. I didnt have too much trouble with the passenger side. Still had to bend fender out of the way and move the wire looms after popping out their clips. Also pulled the power steering reservoir for easier access. Then once the bolt was loose, just punched it through with a 5/8 extension and it came out without too much trouble. I ended up reusing all the same hardware but flipped the thru. bolt the other direction too. Its doable for any future forum goers!
    For drivers side I removed the battery and tray and wire looms and such and bent fender as well.
    But none of that compared to the PITA to dremel out the top, engine side shock mount nut that was just spinning in its cradle. My god.
    Tacotj likes this.
