UCA Rubbing On Tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Allstar780, Apr 11, 2015.
  1. Apr 11, 2015 at 4:36 PM
    Allstar780
    Allstar780 [OP] Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    I was driving on the highway today, on a route I've driven twice in the tacoma with no issue... There was really strong winds causing a bit more roll on the corners than usual, and when going around a banked corner I heard a loud, squealing rubbing sound... That sound was my UCA on the driver side rubbing on the inside of tire.
    I know an easy solution is some half inch spacers or aftermarket UCAs or whatever... However both rims/tires and the lift were installed by the dealership... Should they not cover the costs? I think a bit of paint to touch up the stock UCA and a set of spacers should be realistic expectations... Thoughts on this?
    Here is a picture that shows the clearance between tire and UCA...
  2. Apr 11, 2015 at 4:45 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    What type of lift?
    What size tires?
    What wheels?
  3. Apr 11, 2015 at 4:47 PM
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    Maybe the backspacing on the rim...It clears but barely
  4. Apr 11, 2015 at 4:56 PM
    Allstar780
    Colin
    Alberta, Canada
    XD Series Hoss rims... 17x9 with 5.71 inch back spacing and 18mm offset.
    265/70/17 Duratracs
    3 inch spacer lift / level.
    The parts manager gave me a list of rims they carried that he knew would work for the setup. This whole setup was approved and installed by the service manager
  5. Apr 11, 2015 at 5:04 PM
    murderedtaco23
    Jesse
    Campton NH
    Just scrolling through the first page of rims on tire rack, there are only 2 that have back spacing over 5 inches, most are 4.75, I would throw a half inch spacer in. Yes the backspacing works but it tire roll isn't accounted for. Maybe even go back and get them to pay for the spacers and even try new UCAS while your at it. If it was approved by the service manager your tires shouldn't rub the UCAS.
    Sorry this happened to you man, that sucks
  6. Apr 11, 2015 at 5:07 PM
    Allstar780
    Colin
    Alberta, Canada
    Yeah I think one new UCA and a set of spacers should be reasonable to ask for, especially with it all having been dealer installed... Less than 3000km on the truck and I might already have to get stuff fixed... Not too happy.
  7. Apr 11, 2015 at 10:52 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    New control arm because paint was scuffed off? No.
    Spacers? The dealer likely wouldn't install them.
    IF anything (big if) I would ask to exchange for different wheels.
    Really you should be running adtermarket control arms for better alignment anyway.
  8. Apr 12, 2015 at 3:57 AM
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    3inch lift you need aftermarket UCA to get your alignment to spec
  9. Apr 12, 2015 at 5:19 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I'm sure they'll do something, its a MAJOR liability issue for them. Document and take plenty of photos. I personally would change the wheels to something with the appropriate back spacing, those tires should fit even without a lift and not rub anything.
  10. Apr 12, 2015 at 5:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Looks to me like the list was wrong.
    Actually 'dealer installed fancy stuff fixed', right? Nothing actually wrong with the truck itself is there?
    Don't blame you one bit. Your frustration should totally be with the dealer or whoever made their list up, and I agree with others, they should correct it.
    I don't know how the price you paid them compares to that work when ordering your own parts and having them installed by an independent mechanic, but I'd guess its more.
    If they hassle you too much, have them return it to stock? Then DIY, with the right stuff?
