UCA Rubbing w/ 265/75/16 Wranglers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WestcoastWinch, Apr 6, 2018.
  1. Apr 6, 2018 at 6:39 PM
    WestcoastWinch
    WestcoastWinch [OP] New Member
    Jordan
    2017 Toyota Tacoma
    First off just wanted to apologize for being a new member and asking a simple question off the bat, but im looking for recommendations on how to address the rubbing i encounter when off roading with my 2017 Taco that has 265/75/16 Goodyear Wranglers with a stock suspension.
    On pavement, they are fine. Reversing, full lock, no rub. But when travelling offroad and there is any wheel travel, such as going through a cross ditch, there is noticeable rubbing with the UCA.
    Im looking for suggestions/recommendations on what i should do to remedy the rubbing. From my searching, ive found i could replace the upper control arms with an aftermarket setup that allowed for more room, use wheel spacers or possibly install a leveling kit, but im not sure if this would really fix the issue.
    The vehicle travels almost daily on logging roads for work, so the fix needs to be a good fix and not a band aid or put additional strain on other components of thr truck.
    I should probably add that i have been a Jeep guy since i started driving and i dont think ill ever go back to a Jeep after driving a Toyota.
    Thanks in advanced,
    Jordan
  2. Apr 6, 2018 at 6:48 PM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    I would look into a set of wheels with a bit more negative offset. Or you can always add a set of wheel spacers.
    I have the same size tire on aftermarket wheels 16x8” - 0 offset. No rubbing on flex.
    BassAckwards likes this.
  3. Apr 7, 2018 at 8:53 AM
    WestcoastWinch
    Jordan
    2017 Toyota Tacoma
    Ok, thanks. I will look into the wheel spacers. From all the reading i was doing it seems like sometimes they fit, sometimes they dont. I may proceed with a small lift as well to allow for more room within the wheel well for tire to travel.
    Thanks,
    Jordan
  4. Apr 7, 2018 at 10:05 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Lift might not do anything
    What wheels do you have? Sounds like you don't have enough back spacing for said wheels.
    And spacers might create a new rub on the body mount
  5. Apr 7, 2018 at 10:38 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Lr uca’s are adjustable and will fix it but they can come loose on daily logging roads although mine are as tight as day i got them
  6. Apr 7, 2018 at 11:47 AM
    ZYBORG
    TX / S. FL
    3G TRD OR
    It’s definitely odd to me that they rub but like you said, there are a few reports of people rubbing.
    And alignment might even solve your “issue”. It shouldn’t take much.
    I’d figure out your ultimate goal with the truck (wheels, tires, suspension/lift, etc) and go from there.
    Best of luck, Jordan! :thumbsup:
