UCA rubbing
Discussion in 'Wheels & Tires' started by matttoyota, Apr 15, 2012.
  1. Apr 15, 2012 at 7:38 PM
    matttoyota
    matttoyota [OP] Member
    El Paso, TX
    2001 SR5 4x4 stock for now
    Hey everybody,
    I'm sure this question has been asked before, but what the hell. I'm going to lift my truck 3 inches and go with 285/75/16 tires on stock wheels and I was wondering if that wheel and tire combo will rub on the UCA? My rims are the 16 inch double-three spoke.
  2. Apr 15, 2012 at 7:42 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    They will rub! You'll need 1.25" wheel spacers to clear the UCAs if you intend on running you stock wheels....after market UCAs will be needed too so your alignment can be true
  3. Apr 15, 2012 at 7:51 PM
    matttoyota
    El Paso, TX
    Thanks for the info. That's crazy I didn't think I would have to buy aftermarket uca's just to get the alignment to specs.
  4. Apr 15, 2012 at 7:55 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    No problem man...the Stock UCAs can only adjust so much. I recommend Light Racing UCAs. They have a fully adjustable Balls Joint perfect for Daily Driving and Mild Off Roading...if you intend on doing some hard core wheeling and stuff like that a uni-ball UCA would be better...such as Total Chaos ;)
  5. Apr 15, 2012 at 7:57 PM
    matttoyota
    El Paso, TX
    Thats cool then, I really don't do to much crazy stuff with my truck
  6. Apr 15, 2012 at 7:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Then the Light Racing UCAs are perfect for you and their more inexpensive than the Uni-Ball applications
  7. Apr 15, 2012 at 8:00 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  8. Apr 15, 2012 at 8:04 PM
    matttoyota
    El Paso, TX
    Sweet, thats actually who I wanted to get my lift from.
  9. Apr 15, 2012 at 8:05 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Well there ya go lol! :D
  10. Apr 23, 2012 at 6:46 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    I installed the 3 inch Toytec lift and the camber was nearly perfect. Only had to adjust caster which was only out on the driver side.
  11. Apr 24, 2012 at 5:46 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    So you're getting 2.6 degrees or so of caster with a 3" lift and stock ucas? Impressive, must be a good alignment shop.
  12. Apr 24, 2012 at 11:14 AM
    matttoyota
    El Paso, TX
    Not bad, I hope mine alignment comes out like that to.
  13. May 11, 2012 at 5:12 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    The alignment was actually done at a Toyota dealership. The had the latest and greatest of alignment machines. I watched to whole thing and was pretty amazed. It also helps when your friend is the one doing the alignment.:)
  14. May 11, 2012 at 5:15 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    What dealership?
  15. May 12, 2012 at 4:46 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Universal Toyota
    SATX
  16. Jun 4, 2012 at 8:35 PM
    jimmybee1108
    jimmybee1108 Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    Hey man I live in SA too. Need to install my new shocks and AALs soon. How much was the alignment there?
