UCA separated from truck
Discussion in 'Suspension' started by rackatak, Jun 29, 2011.
  1. Jun 29, 2011 at 5:57 PM
    rackatak
    rackatak [OP] Well-Known Member
    Ok, background on my truck first. 3" skyjacker lift AAL in the rear, swaybar removed, Built Right UCAs, Sport wheels, and 265/70/17 Kumho Mojave AT tires. Now onto my problem, today when I pulled into a parking space I bumped the curb and heard/felt a clunk in the front end. Got out check the truck, no damage or anything out of the ordinary. I get done eating lunch come back out and as I am backing out of the space I feel like something is rubbing so I get out to check on the tires and I find the passenger side tire is caved into the frame. I look closer and the rear of my UCA is slammed into the header. Looks like the bolt has been pulled out of the sleeve that holds the UCAs to the truck. Anyways after I have it towed to my house I look at it again and now the driver side tire is doing the same thing but not to the same degree as passenger side. I look at it and it has the exact same problem, looks like the bolt has been pulled through the sleeve. Now my question is what the hell is going on? Did the nuts just come off? Did the bolts snap under some type of pressure being applied when I bumped the curb? My truck is mainly used on road at highway speeds, I go out once a month and play in the mud, dirt and rocks(kinda, I am a prerunner). What did I miss? I've got photos of the UCAs through the wheel well on both sides.
  2. Jun 29, 2011 at 6:01 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    That sucks. Did you torque them down or hand tighten?
  3. Jun 29, 2011 at 6:03 PM
    rackatak
    I torqued them down. I can't remember what the specs were, I need to research and find them again.
  4. Jun 29, 2011 at 6:07 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    holy shit thats crazy, lucky it happened in the parking lot. so did the bolt break, is it there or did it completely fall out? now ill probly check mine
  5. Jun 29, 2011 at 6:09 PM
    jandrews
    '09 FourDubDee TRD OR
    If torqued to spec there's no way in hell that should happen without the bolt shearing.
  6. Jun 29, 2011 at 6:10 PM
    rackatak
    Yeah very lucky, considering this morning I was doing 80 down the highway getting to work. I am not sure yet. I am getting a jack and tools to work on it tomorrow. The bolt is still in there, can't tell if it snapped off the nut or the nut came unscrewed.
  7. Jun 29, 2011 at 7:57 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    wow lucky nothing happened.
  8. Jun 30, 2011 at 3:54 AM
    Tacoma Joe
    Tacoma Joe Member
    Joe
    Maryland
    09 Prerunner
    Total Chaos
    Anyone know the torque for the bolts ? I'll be replacing my bushings soon and havent seen the torque spec anywhere yet. Other question- how do you fit a torque wrench in there ?
  9. Jun 30, 2011 at 3:58 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i belive its 85ft lbs
  10. Jun 30, 2011 at 4:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use red locktite.
  11. Jun 30, 2011 at 4:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Wow, how can that happen without the bolt coming out or shearing?....was the rubbage on the UCA in that one pic before or after this happened?
  12. Jun 30, 2011 at 5:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    Looks like the nuts are missing and the bolts "walked out" of the sleeve over time.
  13. Jun 30, 2011 at 5:19 AM
    rackatak
    You fit a torque wrench in there with a lil force and proper application of four letter words.
    The rubbing came from when it buckled and the tire rubbed on it when I was turning.
    I'm going by the stealership today to get replacement bolts and nuts. Hopefully that's all I need.
  14. Jun 30, 2011 at 5:45 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Bolts don't have legs. They can't walk. You stop it with your lies!
    But seriously..that's probably what happened.
  15. Jun 30, 2011 at 6:58 AM
    rackatak
    That is what I'm thinking. I went back and found my notes from when I installed the UCAs and the torque specs I had at the time were only 65lbs...I've heard from multiple people now it should be closer to 85lbs. So doesn't surprise me they "walked out"
  16. Jun 30, 2011 at 7:19 AM
    bschmitt09
    bschmitt09 Active Member
    Western WA
    2011 TRD Off-Road Access Cab
    Sucks man, hope theres no other damage as a result of this.
    After you fix it, retorque after a few drives to make sure it doesn't happen again.
  17. Jun 30, 2011 at 7:27 AM
    rackatak
    Absolutely, I will be spending all day tomorrow trying to get this stuff back together. I need a new floor jack cause my old one won't lift the truck with a 3" lift. Found that out this morning. Kinda funny when you fully flex your jack and your tires are still on the ground. I'll be checking every bolt I ever touched on the truck now.
  18. Jun 30, 2011 at 7:31 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Perhaps you torqued to 65 inch lb's?? Stranger things have happened...
  19. Jun 30, 2011 at 7:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'd be stunned if you snapped one of those bolts. They'll bend long before they break. I've snapped an upper control arm in half and bent a gusseted spindle on separate occasions and both times the bolts only bent.
    I'm currently running custom longer bolts with jam nuts to avoid the issue you just experienced.
  20. Jun 30, 2011 at 7:34 AM
    macgyver
    Brad
    Canton, GA
    4x4 block between the jack and the jacking point. Problem solved.
