UCA through bolt not budging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoteva14, Jun 20, 2020.
  1. Jun 20, 2020 at 2:42 PM
    tacoteva14
    tacoteva14 [OP] Member
    Tyler
    Pennsylvania
    2008 maroon sr5 tacoma
    1.5 in lift Spyder halo headlights cap high jack black rhino wheels 32in tires
    Hey everyone,
    I was taking my UCAs off to put some Freedom Offroads on for my 2.5 lift. I got the nut off of the bolt that holds the UCA an absolutely pounded on it and it would not budge. Has anyone had this problem? Tips? Someone save me from taking a torch to the whole thing
  2. Jun 20, 2020 at 6:45 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’ll assume the suspension is unloaded?
  3. Jun 20, 2020 at 6:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Jun 20, 2020 at 7:17 PM
    tacoteva14
    Tyler
    Pennsylvania
    Yeah I have the shock off.
  5. Jun 20, 2020 at 7:22 PM
    gotoman1969
    Unloaded as the Uca is disconnected also from the steering knuckle. So there is zero pressure on the bolt. Being in the north could have some corrosion build up.
  6. Jun 20, 2020 at 7:23 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Just pound it harder, sometimes that’s what you gotta do
    Also that’s what she said
    Kolter45 and imthejaybird like this.
  7. Jun 20, 2020 at 7:30 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Lots of guys have had too cut the bolt out.Better too use a new bolt anyway.
    TnShooter likes this.
  8. Jun 20, 2020 at 8:59 PM
    tacoteva14
    Tyler
    Pennsylvania
    I am able to move the arm up and down freely so there isn’t really any pressure on it. I can’t wrap my head around it.
  9. Jun 20, 2020 at 9:04 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Get the torch out......and a fire extinguisher.
    Zim
    whatstcp likes this.
  10. Jun 20, 2020 at 9:31 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    sounds like corrosion in the frame.
  11. Jun 20, 2020 at 9:39 PM
    TnShooter
    Deogee
    STOCK
    Will the bolt turn at all?
  12. Jun 20, 2020 at 9:56 PM
    imthejaybird
    imthejaybird I make things and do stuff. TTC #287
    Jay
    Burleson, Tx
    2006 Tacoma DCSB
    Soak it with liquid wrench over night, then use the fire wrench in the morning.
  13. Jun 21, 2020 at 12:15 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Quality impact gun. Just did this today on a Land Rover. While the LCA bolts and axle nuts were completely unmovable by hand, a few seconds at 1200ft/lbs break away torque pulled them free like butter. If you don't have air tools I highly recommend this cordless one, which is what I use: Dewalt 20v Max XR. Just be careful what you use it on, it sheared my OEM wheel lock key in half.
    Edit: disregard, I misread as LCA.
  14. Jun 21, 2020 at 6:41 AM
    EYBT
    EYBT Well-Known Member
    Evan
    Oahu, Hawaii
    2014 TRD 4x4
    JBA UCA, Eibach Springs, Bilstein 5100s, 2.5" AAL
    They can be stubborn at times especially as the truck gets older. I encounter this problems on older 4runners and tacomas. Spray some wd40, let it sit, and pound the spindle on different sides to loosen it. Works everytime.
  15. Jun 21, 2020 at 8:28 AM
    tacoteva14
    Tyler
    Pennsylvania
    Thanks to everyone for the advice. I let it soak in freeze off over night and will try this evening to get it out. To clear up some confusion, the UCA can move freely up and down, the nut is off of the bolt that goes through the strut tower (I have it on the end of the threads to pound it through), and the bolt itself will not spin freely. Hence, I think it’s bent inside the strut tower making it not pound up through.
  16. Jun 21, 2020 at 9:53 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    You live in PA. Considering that and the design, it's more likely corrosion than bent bolt. A bent bolt would still rotate.
