UCA with 1 1/2 to 2in. lift.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Oct 27, 2010.
  1. Oct 27, 2010 at 7:21 AM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's set @ 0 with OME 883x coils up front . Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip.
    O K so I have ben reading that it is best to replace the uca when doing a 3in. lift. Is that so if I only lift the front 1 1/2in. to 2in. ? :confused:
  2. Oct 27, 2010 at 7:22 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    They aren't necessary, but it wouldn't hurt anything.
  3. Oct 27, 2010 at 8:34 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    It would really depend on what alignment numbers they are able to get with the stock UCA's? You may or may not need them.
  4. Oct 27, 2010 at 9:00 AM
    tacoma guy
    Joe
    Phoenix Az.
    Ya I can see that. Thanks guys for the replys . Question for toku58 or anyone? Iam hearing that by lifting the 2nd gen tacomas, the vehicle stability cantrol system has ben giving problems? Ia that true and if so how did you get around it?
  5. Oct 27, 2010 at 9:08 AM
    onepremiere
    onepremiere I Tinker
    Jeff
    Left Coast
    True, because we build most caster into our Camburg UCA to correct the geometry change, you may or may not need them. That will all be determined when looking at alignment numbers. I never took an measurements when I did a Fox Coilover and UCA on my truck, so I do not know my exact lift numbers. However, I set the truck up just a hair higher in the front than the STOCK rear end. Unless you really looked at it, the truck appeared to be level. I still have a perfect alignment to this day.
    -Jeff @ Camburg
  6. Oct 27, 2010 at 9:54 AM
    tacoma guy
    Joe
    Phoenix Az.
    To Jeff@ Camburg, Thanks for the info . Your right I wont know untill I get the alignment done. So you did not lift the rear of yours rite?
  7. Oct 27, 2010 at 1:45 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  8. Oct 27, 2010 at 4:35 PM
    tacoma guy
    Joe
    Phoenix Az.
    I just wont to say thank you all for your replys and all the great info. I now have a 99 prerunner and Its fixed up the way i want. I was thinking of selling it to up grade to a 2nd gen. tacoma. I really like these trucks.. But now I dont know if I want to up grade, if I cant fix it up the way I want , whats the point ? :confused:
