UCA with Bilstein 5100s
Discussion in 'Suspension' started by iTzWho, Dec 7, 2019.
  1. Dec 7, 2019 at 6:57 PM
    iTzWho
    iTzWho [OP] Well-Known Member
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Sliders By @Yamadirtrider and @Red_Baron 265 65 18 Falken Wildpeak AT/3 on Black Rhino Tanay Morimoto Retrofit Headlights Bilstein 5100 w/OME 885 Dakar AAL Victory 4x4 18" w Tepui Kukenam 3 RTT Tech Deck with iPad and Phone mount Soon to be lighting 4 KC C2 Scene lights 4 KC Cyclones
    I installed the kit from @HeadStrong Off-Road but im still a little squirrely on the road so I'm assuming it's that.
    Thanks!
  2. Dec 8, 2019 at 10:54 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    How much did you lift the truck? Sis you replace UCAs? Tire size? Stock or aftermarket wheels?
  3. Dec 8, 2019 at 11:08 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Lessen preload. I don’t know why anybody uses 5100s for a lift height that requires UCAs and you’re spending more on UCAs than the entirety of the lift kit.
  4. Dec 8, 2019 at 11:12 AM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Didn't preload.
    My truck went up 3.5 inches in front and 2.5 in rear because of sag.
    I don't have the printout but it was borderline like 1.4 I think.
    265 65 18, black rhino Tanay with Falken Wildpeak at3
  5. Dec 8, 2019 at 11:13 AM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Phone dying and wet won't respond for a few lol
  6. Dec 8, 2019 at 11:13 AM
    T4RFTMFW
    So you have 5100s set at 0 and 3.5” of lift? If that’s the case, you bought the wrong lift coils too. If you’re at or above 2.75” you almost assuredly would need UCAs. At 3.5” your front end is going to ride like shit.
    71tattooguy, gotoman1969 and whatstcp like this.
  7. Dec 8, 2019 at 11:23 AM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    OME 885
  8. Dec 8, 2019 at 1:40 PM
    gotoman1969
    Check and make sure you don’t have the spring seat upside down.
  9. Dec 8, 2019 at 2:56 PM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Okay sorry this is what I have for you.
    I bought the Bilstein 5100 with OME 885 springs from Headstrong offroad because my suspension was sagging from having 140k miles on them.
    When I installed the lift I ended up with a 3.5" lift in the front and 2.5 in the rear.
    I took it to the alignment shop and they told me it was borderline at about a 1.4 and they would suggest UCAs eventually.
    They are a little wandery while I drive, not horrible but noticeable.
  10. Dec 8, 2019 at 3:32 PM
    gotoman1969
    Yep, with that caster number it will feel like crap. You’re
    gonna want at min 3 degrees preferably 4. I run jba ucas and 4 degrees of caster.
    71tattooguy, iTzWho[OP] and whatstcp like this.
  11. Dec 8, 2019 at 3:39 PM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Would you suggest those?
  12. Dec 8, 2019 at 3:42 PM
    gotoman1969
    I’ve had zero issue with my jba’s. They come with 2 degrees of caster built, my alignment guy had zero issue getting 4 degrees of caster. I definitely would suggest/recommend getting them.
  13. Dec 8, 2019 at 3:51 PM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    I have zero idea how it went more than 2.25.
    Im assuming the front shocks and coils were sagging like shit and that's why it ended up being that much.
    I have them both set to 0
  14. Dec 8, 2019 at 4:02 PM
    gotoman1969
    So you saying 3.5” over what you had. So if your original springs were sagging an inch really it’s 2.5 “ of lift.
    iTzWho[QUOTED][OP] likes this.
  15. Dec 8, 2019 at 4:09 PM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    And I have no idea what it was before since I bought it used
  16. Dec 8, 2019 at 4:13 PM
    gotoman1969
    Well you say you got 3.5”’of lift what are you basing that on, did you take before and after measurements, or you actually have no idea.
  17. Dec 8, 2019 at 4:24 PM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    Before and after measurements of front and rear
  18. Sep 23, 2021 at 1:38 AM
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Late post but do I need UCAs? I have bilsteins with 885 at 0. No issues so far
  19. Sep 23, 2021 at 1:59 AM
    iTzWho
    Ethan
    Carbondale Colorado
    2010 Tacoma DCSB
    I did.
    But I also had 5100s instead if 885s.
    Also running a 33" tire was rubbing frame and front bumper.
    Some people can get away without a Cmc and uppers somehow lol
    Tac11[QUOTED] likes this.
