uca with ome lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garyregcab14, May 30, 2016.
  1. May 30, 2016 at 7:38 PM
    garyregcab14
    garyregcab14 [OP] Well-Known Member
    Garrett
    cincinnati ohio
    2014 Tacoma reg cab 4x4
    light bar, king 2.5 w/remote resi, wheel spacers, magna flow exhaust, wheelers progressive add a leaf, fox 2.0 rear shocks
    I recently installed ome struts and 884 coils and after a few weeks it is right at 3in lift, I need upper control arms for alignment but something else I noticed is I only have about 1 or 2 inches of down travel, so when I hit big drops on bridges and such it makes a big bang I believe the down travel is bottoming out on the upper ball joints, and info or suggestions?
  2. Jul 1, 2016 at 2:42 PM
    garyregcab14
    Garrett
    cincinnati ohio
    bump which control arm offers a little more down travel
  3. Jul 1, 2016 at 2:49 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    I believe Total Chaos from what I've read somewhere?
    Help this guy out people, BUMP. Good question for me too. I will be getting UCA soon for my rig.
  4. Jul 4, 2016 at 1:35 PM
    garyregcab14
    Garrett
    cincinnati ohio
    bump no one?
  5. Jul 4, 2016 at 1:38 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Could also remove your swaybar..
  6. Jul 4, 2016 at 1:40 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    Most uniballs offer good articulation. I know JBA has a ball joint UCA that is supposed to have more down travel that the TC uniball. You could also be experiencing the UCA hitting the new coils with the lift height.
  7. Jul 4, 2016 at 1:54 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Its my understanding that LR ucas give better articulation than uniballs
    From wheelers website
    Get more droop travel
    : Light Racing’s arm has improved clearance to get around the spring bucket. With 80° of articulation in the upgraded ball joint and free pivoting bushings, Light Racing’s arm gives you maximum droop travel.
    geekhouse23 and HCJ like this.
  8. Jul 4, 2016 at 2:16 PM
    IronPeak
    AuggieX
    Back to Back
    From another thread, i searched uniball articulation
    It depends on what you want OP. the ball joints of the lightracing UCA's will require less maintenance and have MORE ARTICULATION than a uniball setup.
    Yes, you heard that right. I have not seen a uniball with miss-alignment spacers capable of more than ~ 72* of articulation, most are down around the 60-65* mark. The SPC lightracing uca ball joint is capable of doing 82*
    If you are looking for maximum strength then uniball is the way to go. But if you are like me, and want low maintenance, more adjustability, more potential articulation, and dont beat the eff out of my truck, SPC was the way to go.
    geekhouse23 likes this.
  9. Jul 4, 2016 at 4:27 PM
    garyregcab14
    Garrett
    cincinnati ohio
    yeah I want simple maintenance. I don't plan on high speed offroad just need alignment, and fix wondering on highway, and it would be nice to get more then an inch of down travel
  10. Jul 4, 2016 at 5:24 PM
    IronPeak
    AuggieX
    Back to Back
    The response above was cut and pasted from another thread so the OP part wasn't directed at you, just an excerpt from another post on TW. I believe the LR ucas have some advantages as to alignment as well. I have them and I am happy with them , it's my second set and they never broke or fell out of alignment or anything. Plus they save afew hunderd dollars too. They have a zerk fitting that allows for easy lubrication.
  11. Jul 4, 2016 at 5:30 PM
    IronPeak
    AuggieX
    Back to Back
  12. Jul 4, 2016 at 5:41 PM
    Pigpen
    Dan
    Northwest Montana
    IronPeak likes this.
