UCA's and Alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toku58, Jun 9, 2009.
  1. Jan 20, 2012 at 9:04 PM
    #121
    jspetrovitsis
    jspetrovitsis Well-Known Member
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    Toytec/Eibach front coils, Bilsteins on all four, 2 '' AAL, Light Racing UCA, K&N CAI, Weathertecs front and back, Wet Okoles, Alpine INA W900BT in dash navigation, LED cab lights
    these are the numbers that my truck just came out too with new LR UCA'S. The guy struggled when he put them in so I am worried it is not correct
    Left Right
    Camber: -.03 0.2
    Caster: 2.0 2.3
    Toe: .01 .01
  2. Jan 20, 2012 at 9:08 PM
    #122
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With new UCA's, you should have a little more Caster, and the Camber should be closer. One side is -.o3 and the other is +.2??
  3. Jan 20, 2012 at 9:23 PM
    #123
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Face SPC logos directly out and slide ball joints either all the way out or nearly all the way out. They should be able to get camber to nearly zero on both sides and bump the caster higher.
  4. Jan 20, 2012 at 9:25 PM
    #124
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Jan 20, 2012 at 9:27 PM
    #125
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    the spc logos are facing out, and the ball joints are almost all the way out towards the wheel. the guy was doing lots and lots of adjusting on the LCA's is this normal?
  6. Jan 20, 2012 at 10:35 PM
    #126
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    All adjustments but for toe are done on the LCAs. I'd try a different shop if you're not happy with those numbers.
  7. Mar 8, 2012 at 12:08 AM
    #127
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Toku and Chris,
    I recently installed a lift on my 2012 and was wondering if you could give me some number to look out for when I get it aligned. I want to make sure I get the alignment done right the first time.
    I installed billy 5100 in the front set @ 0 with ome 885, LR UCA, and sway bar relocation. The rear has 5125 and icon 3 leaf progressive w/overload leaf installed. For tires, I am running 285/70r17 firestone destination m/t. If you need more information please let me know! Thanks
  8. Mar 30, 2012 at 2:14 PM
    #128
    MountainMan777
    MountainMan777 Well-Known Member
    CA
    07 TRD Offroad Prerunner
    Ever since i installed a set of Fox coilovers and Total Chaos UCAs on my 07 prerunner no one i take it to can align it. They have all given me different reasons why : Inner tie rods are maxed out and have no thread left to bring in but truck is still toed out and needs shorter tie rods or more thread, Front passenger LCA brackets are bent, Maybe i need more kit other than UCAs and Coilovers? I dont know whats going on but it drove fine before i put the lift on, so whats the deal any insight or solutions or anything is greatly appreciated i need help i dont know how to fix it or who to take it to?
  9. Mar 30, 2012 at 9:24 PM
    #129
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Toe 0, Camber 0 or VERY close.
    Set your LR UCA BJs at +2 (SPC facing directly out) and then all the way out in the slots, before your alignment. Chances are high they will not touch your UCAs period.
    Caster should be within spec, which they should show on the post alignment print out you should receive.
  10. Mar 30, 2012 at 9:25 PM
    #130
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Take pictures of the tie rods ends and your LCA mounts and post here.
    They won't align it or the numbers are shit?
  11. Mar 31, 2012 at 4:53 AM
    #131
    4runner74
    4runner74 2012 DCLB TRD Sport
    Mechanicsville
    12 Tacoma DCLB TRD Sport
    Bilistein 5100 x4, 885 springs, LR UCA, TSB AAl, Wet Okole, Westin Bull, PIAA 520ATP, PIAA 5100, Dominator II Steps
    I have almost the same setup. Although not perfectly happy with it yet, here are my numbers below.
    L R
    .6 Toe .4
    .7 Camber .3
    1.4 Caster 2.1
  12. Mar 31, 2012 at 11:47 AM
    #132
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Those numbers are okay.
    Camber isn't bad but should be able to get closer to 0, IMO. This is why you have those SPC LR UCAs. Did you set them to +2 (SPC out) and the ball joint all the way out in the slot?
    Toe needs to be closer to 0 as well. Though it's in degrees (which is annoying) you can reasonably assume that .4 and .6 are close to 1/8 - 3/16
    Caster should be relatively even, but you're only 1/2* off so no harm there, could have been done to counter road crown but now-a-days most set caster even on both sides.
  13. Apr 2, 2012 at 4:33 AM
    #133
    4runner74
    Mechanicsville
    I am going to try getting more caster this week. I am rubbing some on the cab mount which can be improved.
    DukesTaco likes this.
  14. Apr 2, 2012 at 6:00 PM
    #134
    MountainMan777
    CA
    Ever since i installed a set of Fox 2.5 coilovers and Total Chaos UCAs on my 07 prerunner i cant get it algned anywhere i take it, iv been to 4 shops and they all cant align it and the solutions they suggest dont make sense, aftermarket LCAs, Spindles, New LCA Mounts?? My inner tie rods are almost maxed out my drivers side inner tie rod has no thread left to pull the toe in and its still toed out? Any advice, insight, suggestions are greatly appreciated.
    Drivers side
    Camber: -0.1
    Caster: 3.3
    Toe: -2.44
    Passenger side
    Camber: 0.6
    Caster: 6.1
    Toe: -1.50
  15. Jul 9, 2012 at 10:10 PM
    #135
    xsptaco07
    xsptaco07 Well-Known Member
    Jordan
    Atlanta
    2007 Tacoma Xsp
    xsp package, 20" enkei deep six wheels,33" cooper zeon ltz, borla exhaust, borla intake, carbon fiber trim, weathertech mats, Halo HID lights, black grille surround with mesh, smoked 3rd break and tails, 3" toytec coilovers with bilstein strut, AAL and bilstein 5160 in the rear, led tag lights, led interior lights, NTW plated bumper, anytime fog mod, blue and white cluster swap, UWS toolbox,
    i installed a toytec lift on my truck today. Adjustable bilstein struts that came pre assembled with toytec spring and upper assembly. I plan on getting an alignment as soon as i get my new wheels and tires on. Would it be a bad idea to run the lift without new UCA's??????
  16. Jul 9, 2012 at 10:17 PM
    #136
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    depends how high you went,
    any higher than 1.75 up front and I think you want them.
    I put mine on as soon as the lift went on at 2.5 lift and I love the handling for a lifted truck. Almost shat myself when I drove it to the alignment shop it was all over the place. Got my numbers looking good.
  17. Jul 9, 2012 at 10:20 PM
    #137
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    That would depend on how much lift you set on the adjustable struts.
    It's probably more dangerous to drive before getting an alignment. I was skidding around everywhere on turns for a day until the alignment. Lots of people run lifts without UCAs with varying results but generally positive. Again, the amount of lift is the biggest factor. 2" - likely no problemo without UCAs. 3" - recommended.
  18. Nov 28, 2012 at 8:39 AM
    #138
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    so i've read through this thread and some of the information is still not clear. i have a '12 dclb with 265/70/17 tires. the truck hasnt been aligned since it drove off the lot. since installing the new tires, the truck seems to have a sort of disconnected feel at higher speeds and wanders all over the lane. the truck has also noticeably become harder to turn at lower speeds which im not sure is purely the fault of the tire size change (tires are michelin ltxms2). Since the truck is at stock height are 0* toe and o* camber optimal numbers? since i am aiming for a lighter feel in the steering wheel, what should i aim for as far as caster goes?
    thanks
  19. Feb 6, 2014 at 8:24 PM
    #139
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Do I need UCA'S if I just did the Bilstein 5100 adjustable schocks at top level which is 2.5"?
  20. Feb 7, 2014 at 3:03 PM
    #140
    1tacoplease
    Temecula
