UCA's JBA or SPC?
Discussion in 'Suspension' started by Trdpro1, Dec 13, 2017.
  1. Dec 13, 2017 at 7:04 AM
    Trdpro1
    Trdpro1 [OP] Member
    I'm making my way over from Tundras.com to see if I can get some reviews to help determine which UCA to go with. I am looking at either JBA or SPC arms. JBA is fairly new to the Tundra's which is why I wanted to reach out to the Tacoma owners to get some feedback and thoughts as which one to go with.
    Open to any and all feedback on these two brands to help determine my selection!
    2015 TRD PRO
  2. Dec 13, 2017 at 7:08 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I have spc an very pleased with them no knowledge of the JBA but if they are good as their exhaust systems I imagine they be great also. May I ask why you want to swap out I see you have a pro are you swapping out those coilivers?
    txtaco87 likes this.
  3. Dec 13, 2017 at 7:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm running JBA and love them. There were some issues with the first batches, but those have since been fixed and I haven't read any other negative things since then. Alignment was a piece of cake.
    SPC are also good, and also had issues in the beginning from what I read. The SPC are adjustable, but I personally didn't need that.
    They're both similar price points, so you can't go wrong either way.
  4. Dec 13, 2017 at 7:18 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If I had to choice between only these two I'd probably get JBA. Just too many issues for my comfort with SPC, early on failures, slipping ball joints, still question on bushings. JBA had teething issues that they seemed to work actively and appear to have eliminated.
    DrFunker and EatSleepTacos like this.
  5. Dec 13, 2017 at 7:39 AM
    Trdpro1
    Trdpro1 [OP] Member
    I am running coachbuilder shims and shackles with the stock pro suspension. I will not be replacing the coilovers. Have some SCS wheels on order with a +25 offset. Once those come in I'll be adding the coachbuilder steering kit and new UCAs.
  6. Dec 13, 2017 at 8:06 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Never heard of them before I looked em up they have some pretty nice hardware. That’s gonna be a nice setup you have
  7. Dec 13, 2017 at 8:47 AM
    Trdpro1
    Trdpro1 [OP] Member
    He's big in the Tundra world, makes top notch products!
  8. Dec 13, 2017 at 8:48 AM
    Trdpro1
    Trdpro1 [OP] Member
    Kinda leaning towards the JBA... I like the alignment features of the SPC, but not sure how many alignment shops near me will fully understand them.
    MattCowsmasher likes this.
  9. Dec 13, 2017 at 8:52 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's the main reason why I went with JBA. Don't have to worry about shit, as the castor is built in, so to speak. I was able to get above 3 degrees of castor on my 3" lift, which is good for these trucks.
  10. Dec 13, 2017 at 6:24 PM
    Trdpro1
    Trdpro1 [OP] Member
    Definitely a positive that’s for sure. JBAs seem to appear like a sturdier set too from the pictures I’ve seen of both brands.
    EatSleepTacos[QUOTED] likes this.
  11. Dec 13, 2017 at 6:27 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This has been asked, answered, and beat to death:deadhorse:. I know Bobs got a search function over there.
    Tldr; there's several threads with opinions.
  12. Dec 13, 2017 at 6:31 PM
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    I am currently running SPC and the adjust-ability is a big part of the reason I am able to run 35s, the added adjustment is significant in these and I would only suggest them if you are in need of that function otherwise it is a waste.
    MattCowsmasher and Trdpro1[OP] like this.
  13. Dec 21, 2017 at 7:19 AM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I've been doing a ton of reading on these 2 as I'm thinking UCA's make sense when doing a 2-3" lift since I'll be in there swapping the other components anyway.
    It seems like the SPC have a much large share of the market due to their price point and time in the market. It seems like JBA may be a slightly better built set and for the extra <$100, I think the better build quality, OE bushings, and fewer adjustments are worth the extra cost. Personally I like the colored powder coat vs black of the SPC too.
  14. Dec 21, 2017 at 7:23 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    JBA's for the win, I have had Camburg, SPC's and these by far are the best I have ever had.
  15. Dec 21, 2017 at 7:30 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I'm satisfied with my Camburgs (unlike @Unchained 5150, I know) but the reason I went with them is the same reason the JBA would be my close 2nd - OE ball joints. In the case of mine it's a Moog equivalent but I could use Toyota if I wanted to spend the scratch for unneeded UCAs to get them. The JBA I believe uses a standard GM truck ball joint. Point being it's an advantage to me to use readily available components compared to proprietary parts.
  16. Dec 21, 2017 at 7:30 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The trick is to set the SPC's and not tell the alignment shop about them. Where you located?
    rlx02 likes this.
  17. Dec 21, 2017 at 8:16 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm not sure where you're getting your prices, but JBAs are like $20 cheaper
    OG_Tacoma and MattCowsmasher like this.
  18. Dec 21, 2017 at 8:20 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I can find LR/SPC UCA'S new for $375 shipped, how much can you find JBA's new?
    jerzsubbie and MattCowsmasher like this.
  19. Dec 21, 2017 at 8:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Really? Where are you finding that price? That's impressive. My JBAs were $467 shipped to me.
  20. Dec 21, 2017 at 8:24 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    SPC’s here, Love em!
    MattCowsmasher and ChadsPride like this.
