UCA's necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Mar 2, 2016.
  1. Mar 2, 2016 at 9:17 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Planning on lifting my 3rd gen a little, but wondering if UCA's are REALLY needed. On my 2nd Gen I was running 5100's with OME 885/ Icon 3AAL and the shop got it aligned perfect(with stock UCA). Will the 3rd Gen be much different? I plan on going a little higher ~2.5-3" with this setup;
    -5100's w/ 887 @ .85
    -5100's rear with icon 3leaf AAL and overload left in
    -17" FN FX PRO w/ 285/70/17
    Suggestions? Thanks!
  2. Mar 2, 2016 at 1:16 PM
    Buddha717
    Buddha717 Well-Known Member
    Ron
    Harrisburg, PA
    2016 Inferno Tacoma TRD sport DCLB PTJBL
    I have basically the same set up and chose to run UCA. The reason is because with this set up you'll be right at the limit. Some have said they didn't get the UCA and had either a problem with high speed wobble or alignment issues. Having the UCA will give you the largest adjustment choices.
    Dean724, MESO[OP] and llibrm like this.
  3. Mar 2, 2016 at 1:53 PM
    MESO
    State of Jefferson
    Thanks! Ordered a set just to be safe.
  4. Mar 2, 2016 at 2:40 PM
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Ask the company your purchasing from. Besides alignment, my experience with aftermarket UCA is you will also get more travel meaning lower wheel drop which helps in technical off-roading and articulation. Most it add typically is about an 1 inch in 2-3 inch lifts.
  5. Mar 2, 2016 at 3:31 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Undefinitized Contract Actions are frowned upon...oh wait
