UCA's needed for Bilstein 5100 or similar OME lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Munney, Feb 20, 2017.
  1. Feb 20, 2017 at 8:25 PM
    Munney
    Munney [OP] Well-Known Member
    Hey all, newbie to lifts here, are UCA's a necessity? If not what's the benefit of purchasing them? Any info is appreciated!
  2. Feb 20, 2017 at 8:30 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    You can get away without new UCAs if you're not lifting more than 2".
    The benefit is having more adjustability for proper alignment.
  3. Feb 20, 2017 at 8:43 PM
    Munney
    Gotcha, thanks for the info, sounds like it is an option if you're not going over 3"
  4. Feb 20, 2017 at 8:46 PM
    Bishop84
    Bishop84 Well-Known Member
    If you want 100% done right, even with a 2" it's the way to go, it rides better with less camber and more caster without compromise.
  5. Feb 20, 2017 at 8:49 PM
    Munney
    Right, so might as well save up a few extra bucks and do it right, that was my concern, is it just a marketing scheme or are they really worth it, sounds like they are.
    Sandeman likes this.
  6. Feb 21, 2017 at 3:43 AM
    Sandeman
    Sandeman Well-Known Member
    Home of the Headless Horseman, NY
    '17 TRDOR, '04 GX470
    On the bright side, OME lift kit and UCAs are usually more than adequate for most on here, Id say about 70% members in here don't really need the $2000+ set ups they have
    No hate, that's their bank account, just giving my .02s about the lift kits you'll see on here
  7. Feb 21, 2017 at 3:58 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    If you're going to be lifting and keeping it at 2-3 inches or less, UCAs are a total waste of money, and in fact make the whole thing more labor-intensive, both at the installation phase and at the routine maintenance phase.
    I personally would not run them in the situation you described. I certainly wouldn't buy them again.
    Jukeboxx13 likes this.
