UCAs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blackdawg, Aug 6, 2011.
  1. Aug 6, 2011 at 12:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Okay ppl..i am a little confused on UCAs. Why to TC ones cost 700 big ones and Allpros cost 450?? Advantages to them? whats the big design differences it UCAs?? How much better do they actually help?
  2. Aug 6, 2011 at 6:52 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    You get what you pay for.....is the main idea here.
  3. Aug 6, 2011 at 10:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay...but what are the advantages of the uniball design??
  4. Aug 6, 2011 at 11:25 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    With a extended coilover, it will gain wheel travel 1-2" , and this will be a Midtravel.
    Just the arms, they are stronger, smoother cycle with the uniball. And the uniball is allowed to be at angles farther than the Balljoint when Lifting higher than 2.5" inches. I wouldnt mine having a set of Allpros or Total Chaos upper arms. Both companys have good service and product.
  5. Aug 6, 2011 at 1:15 PM
    Tacoma mud
    Tacoma mud Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    I dont think you can use all pro ucas with kings or icons, i might be wrong tho. Im gonna get the TC btw :D
  6. Aug 6, 2011 at 1:24 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    uniball allows for more articulation off road and smoother wheel travel at highways speeds. Plus the fact that you can better align your front end with a uniball as opposed to a balljoint, less binding and wheel travel are also advantages
    alot of people will argue that stock ucas are the strongest you can get, but you're right, when lifting the ball joint becomes weaker because of the added extension provided by more than 2.5 inches of lift. If OP just goes with billy 5100 up front and a leaf pack or aal in the rear he will not need new ucas
    i recomend camburg, TC is a good choice as well, but camburg has improved their design recently with a 1" uniball, minimal to almost no binding with 3" lifts and the price blows tc out of the water
  7. Aug 6, 2011 at 1:37 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Yea the TC r like 750 and the camburgs r 550, both are top brands and havent herd any bad thing about them. Its all on how much your willing to spend.
  8. Aug 6, 2011 at 2:50 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thats right, theres not point if hes gonna run 5100's, even with my sway away coilovers at 3 inches of lift with stock UCA , im still good. I wish i had UCAs. I guess ill just save for long travel.
  9. Aug 6, 2011 at 4:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I didn't just go with billies, i have them but i have Eibach coils, so i have a lil over 3'' of lift. Plus in the rear i have wheelers 5pk with a AAL in it and 1.5'' shackles. Definatlly over 3'' there.
    Im just curious as my ball joints look like shit and like they are REALLY bent over. ill post a pic
  10. Aug 6, 2011 at 7:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    here are ball joints...
  11. Aug 6, 2011 at 8:20 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    It would be a good idea to get new ones but its not really necisary. They would just help your truck flex better :D
  12. Aug 6, 2011 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I think UCAs will be my next mod. Not TCs and not All Poos though. Probably the 1" Camburgs.
    My buddy has the APs and they work but are noisy. He's constantly having to put that teflon lube on them to quiet them down. Not sure if it is a design fault or just his. And the TCs are just too much money.
    Last time I looked, wheelers had the Camburgs for $529.
  13. Aug 6, 2011 at 9:38 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    ^^^^^ x2
  14. Aug 6, 2011 at 9:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i was just using allpros for the "cheaper" brand and TCs for most expensive. Have read Camburgs are quite good tho too.
    I think i might add these to my list of "to do", i think it'll just help in the long run i guess. I'll end up with Camburgs or TCs prolly.
  15. Aug 6, 2011 at 10:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey Man, I hear what you are sayin'. Kinda where I'm at.
  16. Aug 6, 2011 at 10:48 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    From what ive herd the camburgs are just as good as the TCs but their like 250$ cheaper!
  17. Aug 8, 2011 at 11:38 AM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    A lot of the price has to do with the size of the company. All other things being equal, a smaller company that sells less product will have less of a buffer to re-coop the R&D costs, so the cost the the item will be more. There's also a higher likelihood that the products are hand made, not mass produced (also increases cost).
    That said, the design of all the UCAs described have many differences that effect the overall cost of the item. Uniballs are expensive to produce, but offer more possibility for articulation, and are beefier than stock balljoints.
    my two cents...
  18. Aug 8, 2011 at 11:48 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I just installed my TC UCA's on Saturday and it's night and day over stock with amount of travel you get. Just to get my 5100's out we had to stand on the rotor and after installing the UCA's the extending travel FOX CO's went right in hell i have to push up on the LCA to line the bolt up. If I were you I would get the Uniball UCA's.
  19. Aug 8, 2011 at 5:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks great JLee!
    You think it'll help a lot even with my Eibachs and 5100s?? More travel is ALWAYS good. Plus i think my alignment is WAY off lol
  20. Aug 8, 2011 at 6:12 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Yea theyll help with your alignment
