UCA's
Discussion in '1st Gen. Tacomas (1995-2004)' started by HalfJap, May 7, 2016.
  1. May 7, 2016 at 2:09 AM
    HalfJap
    HalfJap [OP] Active Member
    Evanston, Wy
    2000 Tacoma TRD
    Has anyone swapped an outdated Trailmaster 6" lift to newer tech. Knuckles?
    And the UCA's?
    My main question is about UCA's. Looks like I'm going to fork out +$2,000.00 for a Fabtech lift kit. I will swap all parts and have a new parts lift. The UCA' im looking at, only ones found so far Camburgs, state I have to run 16 or 17" wheels. Why not what I have 15"?
    Any helpful input appreciated.
  2. May 8, 2016 at 9:53 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    You could prolly just order fabtech spindles and struts then locate some oem uca's and be on your way?
  3. May 8, 2016 at 10:17 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    sounds like a waste of $2000 to me. thats the start of a basic LT kit or SAS.
  4. May 9, 2016 at 11:12 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    considering on a drop bracket lift you cut out the stock lower crossmember, the truck's frame would have to be rebuilt to go with anything other than another drop bracket lift kit...
    as for wheel size, with the DB lift, OP shouldn't have any UCA clearance issues with the 15s.
  5. May 15, 2016 at 2:23 PM
    trucker98
    trucker98 New Member
    Richard
    1998 toyota tacoma
    Try fab tech part numbers FTS70007D FTS70007P or FTS26000BK
  6. May 15, 2016 at 2:25 PM
    trucker98
    Richard
    1998 toyota tacoma
    Let me know what you figure out I have the same problem but have not had time to do any calling on the parts
